Old 10-16-2022, 02:39 PM   #1
72SB
72 12 bolt 4 series to 3 series swap?
Have a 12 bolt with 3:73 and would like to put in 3:08. Not finding 3:08 for a 4 series
Do I need to sap out entire rear end housing or?
72SB is offline   Reply With Quote
Old 10-16-2022, 03:08 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: 72 12 bolt 4 series to 3 series swap?
Just the carrier
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-16-2022, 03:18 PM   #3
72SB
Originally Posted by Warrens69GMC View Post
Just the carrier
Good to know
Are the stock axles, 72 6 cyl, 30 spline?
If so this 3 series Eaton and a 3 series gear set would work
https://www.summitracing.com/parts/etn-19587-010
Old 10-16-2022, 03:46 PM   #4
Warrens69GMC
I believe so, but wait for someone else to chime in.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 10-16-2022, 07:36 PM   #5
72SB
30 spline
GM 12 BOLT SPECS
Applications:
1964 - 1982 Chevrolet & GMC 1/2 ton to 3/4 ton trucks
Full/Semi Float:
Semi floating rear axle
Ring Gear:
8.875"
Axle Spline Count:
30 spline
Axle Tube Diameter:
3.00"
Pinion Diameter:
1.625"
Pinion Spline:
30 spline
U Joints:
1310 series
Ratios:
2.50 - 4.56 : 1
Carrier Break:
2.50 - 2.76 | 3.42 -4.56
Identification:
12 bolt rear cover, passenger car version has a different cover and is easily distinguishable
GM 12 Bolt axle identification
Old 10-16-2022, 07:43 PM   #6
zosoppp
but which side of the carrier break is 3.08(3.07)?
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights
zosoppp is offline   Reply With Quote
Old 10-16-2022, 08:42 PM   #7
72SB
My understanding is 3:08 gears only are for 3 series carrier. 4 series starts at 3:73 and goes numerically higher
Truck 12 Bolt Series 2 = 2.73 - down (smaller numerically) Series 3 = 2.76 - 3.42 Series 4 = 3.73 - up (larger numerically)
Old 10-17-2022, 07:35 PM   #8
MikeB
MikeB's Avatar
GM 12 Bolt Truck carrier breaks:
2.73 & Down
2.76–3.42
3.73 & Up
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
