Old 10-20-2022, 08:01 AM   #1
nicholasmansfield
Lowering Height question
What size lowering would look good on this old truck? Tires are 15x10 275/60/15 and 15x7 255/60/15. I measured 1 1/4” rake. I believe it has factory springs.
nicholasmansfield is offline   Reply With Quote
Old 10-20-2022, 09:11 AM   #2
cj847
cj847's Avatar
Re: Lowering Height question
My vote is 2.5/4 on a truck if you want to drive it and not break the bank.
cj847 is offline   Reply With Quote
Old 10-20-2022, 10:23 AM   #3
SCOTI
SCOTI's Avatar
3/5 or 4/6.
Assuming it's a truck-arm set-up, 3/5 is as easy as swapping front spindles & rear springs w/some drop blocks & new U-bolts.
4/6 is spindles, trimming the current coils or using new drop coils. Rear would be more aggressive drop springs + some drop blocks & new U-bolts.
Watch-outs would be F & R wheel back-spacing.
It would also be a good opportunity for fresh shocks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-20-2022, 12:09 PM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Really depends on what YOU want it to look like and how much YOU want to spend. There are a Lot of options. What did the Dog say.
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-20-2022, 12:23 PM   #5
72SB
IMHO, if dropping front, I would use lowering coil springs vs drop spindles. For me, anything more than 3" blocks in the rear gets sketchy so consider "lowering springs" for that also
Then there will be DL angle adjustments to deal with. Generally, a spacer between trans and rear mount (at least 1/2") and a 2-4 degree shim with the rear blocks. You just need to measure angles and go from there
I would look into RideTech for their "progressive" lowering front coils if they make them for C10. I have them on my 67 Camaro and really like them
72SB is offline   Reply With Quote
Old 10-20-2022, 04:58 PM   #6
dagnabbitt
dagnabbitt's Avatar
It is my impression that a 2/4 drop is the easiest thing to do first: since it can be accomplished with springs alone and is not extreme enough to affect DL.
I also think its a nice look for a LWB like yours. And if it is not low enough, keep the springs and get spindles and a flip kit later on.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-20-2022, 06:47 PM   #7
MySons68C20
MySons68C20's Avatar
I did a 2.5" spindle drop on the front and a 4" coil spring drop in the rear.
This pic shows the finished product with an additional 1" drop block in the rear for a total of 5" drop in the back.
Please keep in mind this was all new springs etc not squatted out original equipment.
MySons68C20 is offline   Reply With Quote
Old 10-20-2022, 08:04 PM   #8
Accelo
Accelo's Avatar
Larger tires help the look as they fill the wheel wells better.
The advice given is valid.
Any lower and you end up having to notch the frame in the rear.
And the A arms will require work to facilitate the alignment.
You will also start ridding on the lower bumpers or worse yet the steel stops.
The short story is to go below the above recommendations requires lots more money.
Or compromising the ride quality. Which is pretty good for an old truck.
Cheers
Accelo is offline   Reply With Quote
Old 10-20-2022, 09:53 PM   #9
SCOTI
SCOTI's Avatar
Agreed. Taller tire > shorter on trucks (within reason). The parts suggestions provide multiple options which makes sense since there's more than one correct way to approach the lowering mods.
Usually, you won't need to notch the frame (<6" rear drop). Beyond that, they're a necessity.
Not sure what "work" is being referenced? Care to elaborate on this statement?
This is why I always recommend spindles first on trucks. It keeps the springs as long as possible which only helps suspension travel range.
Cheers
Yes & no. What's that saying? Good, fast, cheap.... You can choose two.
If a guy is handy w/fab work, you can get these trucks low & still have a decent ride on the cheap. You can also get a crappy ride throwing together a poor combo of shiny new parts.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-20-2022, 10:09 PM   #10
CastIron
CastIron's Avatar
I personally would leave it stock, but if I was going to lower it I'd just use lowering springs and drop it just a bit in the front, a bit more in the rear. I personally don't like lowering spindles on a truck that is going to be used anywhere besides the street. I'd rather have the extra ground clearance under the lower control arms. And using lowering springs can definitely improve the handling. There is a limit to lowering springs in the front though, if you care about proper alignment and tire wear.
Your wheels look great, by the way.
CastIron is offline   Reply With Quote
Old 10-21-2022, 07:00 AM   #11
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Actually, drop spindles are the way to go because the steering and suspension geometry remains intact. I didnt have to do anything to the A-arms or control arms, nothing is required if you use drop spindles! Drop coils change everything, shock height, steering geometry, and camber as well as toe in and suspension travel
. As long as you dont exceed 4" inches of drop in the rear you generally wont need to C-notch the frame or relocate the shocks. The panhard bar will either have to be bent slightly or replaced with an adjustable one to center the rear axle. Again, if you dont exceed 4" inches of drop or less the rear shocks and panhard bar will work. I gave my truck the 2-1/2" drop spindles up front and 4" drop springs on the rear. I bent the panhard bar and installed a set of shocks that are 3" inches shorter. I didnt have to do anything to the drive line angle because the pinon angle is still well within spec. Larger diameter wheels and tires will help with filling the obvious opening around the tires but keep in mind, larger diameter tires will change (lower) the speedometer reading...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 10-21-2022, 11:38 AM   #12
SCOTI
SCOTI's Avatar
Not necessarily. Some times wheel back spacing impacts things when using drop spindles. There is possibly a need to trim the a-arm 'gutters' in some (many?) situations.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-21-2022, 01:39 PM   #13
72afr
Beep! Beep!
72afr's Avatar
I've got the same size tires as you, with the exception of the wider rear rim. I have a 2.5" spindle set up front and 3" spring in the rear. As SCOTI mentioned above, I had to trim my lower A-arms to work with my rims. I recommend scouring photos and finding the look you like and go from there. Here's mine as I just need a reason to post it.
1972 Chevrolet C/10 shortbed, stepside, 350, HEI, Fire Engine Red, Black Interior, Former Army cargo transport
2003 Chevrolet 2500HD CC 6.0 4wd
2004 Jeep Rubicon some aftermarket stuff...
2019 Jeep Unlimited Rubicon (the wife's baby hauler)
72afr is offline   Reply With Quote
Old 10-21-2022, 03:53 PM   #14
SCOTI
SCOTI's Avatar
Good looking set-up. Very easy on the eyes.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-25-2022, 04:43 PM   #15
OL SKOOL
OL SKOOL's Avatar
I wonder why some trucks are different. I have same combo wheels and tires and drop spindles. Lower a frames are not even close to touching the rim. 15x8 truck rallys front and rear. Nice truck by the way. I agree with SCOTI for sure drop spindles first no front-end geometry changes.
OL SKOOL is offline   Reply With Quote
Old 10-25-2022, 05:16 PM   #16
Accelo
Accelo's Avatar
It's all about wheel back spacing.
Unless you know the back spacing figure something like a 15X8" doesn't mean a thing.
BTW my wheels have a zero offset, no backspacing the hub is exactly in the middle of the wheel.
Cheers.
Old 10-25-2022, 06:09 PM   #17
SCOTI
SCOTI's Avatar
Cheers.
'Zero offset' is 4.5"BS on an 8" wheel width. Old school math vs Metric era math is still math (for those that are unfamiliar w/the topic).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2022, 02:57 AM   #18
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Pictured is my truck with 255/60 17 tires on 17 x 8 TT2's. Those tires are the same height as the 255/70 15's I've had on my stock height trucks. Its in the process of getting a 2 1/2 inch drop front spindle and 4 inch rear dropped spring with an adjustable panhard bar and shock relocators. Also the whole front end is being replaced with the exception of the control arms and I'm from what I've read shouldn't have any issues. Just wanting the little lower and level look I see on trucks and really like.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 10-26-2022, 07:37 AM   #19
dagnabbitt
dagnabbitt's Avatar
That's an important consideration: but if using springs only, could you not correct the geometry changes with an alignment and new shocks? The reason I ask is because I have a drum brake truck, and I am simply not ready to put discs in front. That is a few years down the road for me.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 10-26-2022, 09:27 AM   #20
SCOTI
SCOTI's Avatar
You can set the alignment using drop springs only.
The main benefit of the drop spindles is the travel distance of the suspension remains unchanged. When using a drop spring, it reduces the travel range of the suspension as it cycles.
For the best ride quality, you want to target the longest spring/shock combo you can fit within the mounting points.
Mild drops w/springs only are certainly possible & can function w/o issue. There are occasions where Camber alignment to era specs is a PITA but if targeting modern Camber set-points it's usually not an issue.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-26-2022, 07:48 PM   #21
67C10Step
67C10Step's Avatar
Another 2.5/4 drop here. Spindles in front and progressive springs in the rear. Not as slick and sexy as 72afr’s truck, maybe someday though.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-26-2022, 08:42 PM   #22
Already Gone
Great stance on the truck. Are those 275 tires front and back ?
Old 10-26-2022, 10:21 PM   #23
davischevy
davischevy's Avatar
The first picture is with 2/4 drop and 17" wheels. The second is with a 3/5 drop, with 22" wheels.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 10-27-2022, 10:52 AM   #24
72afr
Beep! Beep!
72afr's Avatar
Ha! My truck's nickname should be Lucky. The stars aligned just right for this to come together the way it did. I had no business getting this result and if I were to do it today, it'd be no where close. Your build is coming along great! You just gotta leave that CJ5 alone for a bit.
Old 10-27-2022, 11:09 AM   #25
67C10Step
67C10Step's Avatar
Thank you. Those are 255's all the way around. I've not done the power steering conversion yet so I figured a 10" wide or so tire is all I wanted to strong arm around for now.
I hear you! Truck got new exhaust last weekend and I'm starting to sort the parts I have for the power steering conversion. Still need new hoses, crank pully, and whatever rag joint I will need. Trying to get the transfer case and drive shafts back in the CJ just so I have some work bench space!
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
