![]() ![]() Join Date: Oct 2015
Two Underhood Wiring Harness's
For sale are 2 underhood wiring harness's. Both are for front lighting/horn/generator/volt regulator/and on to the junction block on firewall.
Harness #1 (pic 1,2 and 3) is in very good and clean condition, all plugs intact. This harness wasn't for gauges as the feed with 2 inline 3amp fuses is not present. Harness #2 (pic 4) is same as #1 except it does have the ammeter feed wire present. This harness is missing horn wires and plugs and needs cleaned up and retaped in some areas. The ammeter feed in harness 2 could be worked into harness #1 easily and you would be set up for gauges. Both harness's will fit in a USPS medium flat rate box ($16.50 to conus), so shipped price is $35 to conus.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE Last edited by tim71; 11-05-2022 at 10:34 PM. Reason: lower price |
![]() Join Date: Sep 2007
Re: Two Underhood Wiring Harness's
not bad... either one of these 67?
1967custom |
I’m not sure what these harnesses came out of other than they’re Chevy, based on headlight plugs. I purchased multiple harnesses trying to reconstruct the harness in the 72 Blazer I’m refurbishing. Finally I achieved a working complete harness, so I thought I would move these along to someone who could use these as is or for parts.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) 2004 Corvette Z06 CE |
TTT with new price $35.00 shipped
| Bookmarks |
