Old 01-04-2004, 01:29 PM   #1
redneck_motorsports
redneck_motorsports's Avatar
6" Skyjacker Softride SYSTEM
Front and rear 6" Skyjacker soft ride springs w/steering knuckle arm. Took this off my 67 K20 to go bigger. This lift will also fit other applications but would have to measure springs on you application to confirm. Front springs need bushings but other than that this kit is in very good condition. I am asking $600 OBO. I'm in Texas 79065 area.
Thanks,
Catfish
redneck_motorsports is offline   Reply With Quote
Old 01-04-2004, 02:08 PM   #2
Scrub
Collector of rusty Items
Scrub's Avatar
Hey Catfish,
What are you calling a steering knuckle arm? The pitman arm that goes on the steering box or the steering arm on the axle? Is it a drop arm?
good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 01-04-2004, 04:10 PM   #3
redneck_motorsports
Originally posted by Scrub
Hey Catfish,
good luck
The one that bolts to the axle. It came with the kit to correct the steering geometry. This enables you to use your stock draglink and pitman arm.
Catfish
Old 01-04-2004, 04:35 PM   #4
Scrub
Scrub's Avatar
I guess Pitman arm and Draglink and steering arm mean explict things to some people, I always get confused as to which end they hook up to.
So what axle does it fit? I assume a dana 44
Thanks and good luck
Scrub
Old 01-04-2004, 04:39 PM   #5
redneck_motorsports
D44 is correct.
I have alot of stuff, some of it is here
