Old 10-23-2022, 10:43 AM   #1
65chevysub
65chevysub's Avatar
lowering 3/4ton longbed
Has anyone done a slight lowering of their 3/4 ton long bed? I'm throwing the idea around but want to see what is involved, and how it will look. I have an 84 Sierra 2500 with the HD rear axle. It's my daily driver that I use to go camping, or just out exploring dirt roads so don't want to go too low if I do lower it.
65chevysub is offline   Reply With Quote
Old 10-23-2022, 10:59 AM   #2
kipps
Re: lowering 3/4ton longbed
2wd or 4wd?
If you have the full-float rear axle, I assume it's a c20 with a big-block engine. Unless someone swapped the full-float into it.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 10-24-2022, 03:49 PM   #3
SCOTI
SCOTI's Avatar
I lowered my c2500. It's not a Sqaure. But functionality wise, it's also not much different. The same logic I applied to my Squarebody dually applied to my 3/4 ton (c2500/CC/SWB).
What are your specific concerns?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-25-2022, 04:24 PM   #4
Wikid61
Wikid61's Avatar
Cut one wrap off the ft. coils. Move the spring hangers up 2" in the rear.
"Envy is a declaration of inferiority". Napoleon Bonaparte.
Wikid61 is offline   Reply With Quote
Old 10-27-2022, 09:47 PM   #5
5025speed
Wikid61 What would that do to the ride, loading/towing capacity etc, what would be the downfall of this?
5025speed is offline   Reply With Quote
Old 10-27-2022, 09:54 PM   #6
Wikid61
Wikid61's Avatar
The front will firm up, and corner tighter. The rear is still the same rating/ride. It will have a lower center of gravity. Upgrading shocks & adding a rear sway bar will further improve the truck.
Old 10-28-2022, 06:34 PM   #7
65chevysub
65chevysub's Avatar
Originally Posted by kipps View Post
2wd or 4wd?
Standard 3/4 ton, 2wd with the HD rear axle. Engine is a 350 with a TH400
Old 10-29-2022, 08:06 AM   #8
kipps
Unless it was special ordered, the full-float was swapped in there, or the big block was swapped out. GM literature specifies a semi-float for all 1981+ c20 and k20 trucks. The exception, was c20 big-block trucks got the full-float.
