10-25-2022, 09:45 AM | #1 |
Body bushing replacement
Im getting ready to order complete body and radiator support bushings was wondering who has the best and complete kit that has worked out with out a issue? Thanks
10-25-2022, 10:19 AM | #2 |
Re: Body bushing replacement
Classic parts , You'll also need core support mounts , Don't buy urethane unless you like squeaking
https://www.classicparts.com/1967-72...ctinfo/35-145/
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
10-25-2022, 10:26 AM | #3 | |
https://www.classicparts.com/1969-72...ctinfo/78-635/
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
10-25-2022, 10:34 AM | #4 |
Thanks ,for the quick response, I’m going to get them ordered
10-25-2022, 11:34 AM | #5 |
I may over-tightened mine and the rubber split.
One thing the imports never get correct is the durometer of the rubber. The replacement mounts were also cone shaped, didn't look anything like the originals. I know Frank's Pickmups carries two different sets. One is OEM quality? Cheers |
10-25-2022, 12:13 PM | #6 | |
10-25-2022, 12:18 PM | #7 |
I bought mine (rubber) from Classic Heartbeat. Great quality
72 C10 lwb fleetside -stock 350/350 combo |
10-25-2022, 05:19 PM | #8 |
Both Franks and Classic Heartbeat are located in Olympia WA.
Franks sells on this board but to my knowledge doesn't do internet sales. At least as far as I know. |
10-25-2022, 05:40 PM | #9 |
The kits I got from Classic Parts was good quality stuff and I had zero issues. Been drivin the truck for two years still all good.
10-26-2022, 12:02 AM | #10 |
I just did a test fit setup of the radiator support this week. I sourced new radiator support to frame bushings from Classic Parts. You only need one kit. It has a set of two bushings Fit was exact to the ones on my 72 but cannot confirmed they were original. I had to cut the ones on the truck out due to very bad corrosion. Parts on the truck were not really identifiable until I saw the new kit. All the parts needed are in the set and appear to be of reasonable quality. I will echo the opinion of rubber over urethane. The harder Urethane will provide zero improved benefit unless you are looking for every last drop of chassis performance for racing and don't care about noise and harsh ride.
