Old 10-26-2022, 10:24 PM   #1
chewychevy67
R134 with stock condenser. Will it cool or?
Should I put a parallel flow in? I'm doing a factory looking restoration and I'm doing some work to the rad support and now is the time to make the decision. I hear you can't flush parallel condensers. Im in Canada , not Arizona, so it gets warm but not blistering hot. Anyone our there with experience? I also have the poa recalibrate already and I'm using all new components and have a nos condenser.
chewychevy67 is offline   Reply With Quote
Old 10-27-2022, 09:57 AM   #2
72c20customcamper
72c20customcamper's Avatar
Re: R134 with stock condenser. Will it cool or?
My 85 will freeze you out . I converted to 134a with pretty much everything factory stock . Changed out the POA and pressure switch been 2 years since I had it done .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-27-2022, 12:24 PM   #3
LNP
I use to convert them all the time in my garage work days. All you need is the R134 schrader valve conversion kit. Screw the new fittings over the R12 ones and you're in business. Take the valve core out of the R12 ones first.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 10-27-2022, 02:29 PM   #4
Keith Seymore
Keith Seymore's Avatar
Same with my '87. I did nothing except change the fluid type and it is perfectly fine.
Been 13 years in my case.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-27-2022, 05:03 PM   #5
chewychevy67
Awesome. Thanks guys. I'll just keep the stock condenser ten.
