10-27-2022, 08:33 PM | #1 |
Crazy Question (Let Me Know If You Have Tried)
Hi Guys,
I just received an intermittent wiper delay switch and module for my 80 Jimmy. The S & M being 45 years old are need of a deep cleaning. I disassembled both with no issues but have a question about the switch lens. The lens is connected to a metal frame that clips to the switch housing. (I'll post a pic here in a little while) I don't think there is a way to remove the lens from the switch housing without destroying the lens. So, my thought was to just dunk the lens and housing under water to clean it. There's nothing to damage from getting wet and the water that get in between the housing and lens should eventually dissipate, even if I need to stick it in a bag of rice. So, has anyone tried this? Will it work? Something I'm missing? Let me know what you think. Thanks, Scott |
10-27-2022, 08:36 PM | #2 |
Re: Crazy Question (Let Me Know If You Have Tried)
Here’s a pic of the part I’m trying to clean up
10-27-2022, 08:52 PM | #3 |
I think I would try a computer keyboard cleaner.
This is the best link I can find currently. Link: https://www.officesupply.com/technol...se%20-%20Broad
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
10-27-2022, 09:03 PM | #4 |
Certainly won’t hurt. Once it soaks, rinse and then just blow it dry with an air compressor nozzle.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
10-28-2022, 08:17 AM | #5 |
If that doesn't work, maybe some plastic scratch repair stuff like they use on cheap plastic headlights will do something.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
10-30-2022, 08:55 AM | #6 |
I be leave you can bend the steel side clips but very be careful
and genital with it to take off the plastic cover but do not cleaner on the print under the and do not rub light tap real lower air pressure water moist only. clean the rust steel clips paint or clear coat semi-gloss or sating clear. Then genital put all back you can hand buff the front edges if the rust dep imbedded in the plastic, just take care not to scratch print
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
