Old 10-29-2022, 02:58 AM   #1
MiniD
1985 C10 with TBI
I have a 1985 C10 that "had" TBI on it. Someone did some work on the engine a while ago and it never ran right after. A couple of owners later, someone decided to remove the TBI and install a carb. It still didn't run right, so they looked at the rockers and saw that it looked like a couple weren't moving right. They replaced the cam and it started purring.
So... now I'm sitting with a TBI harness that I'd like to remove. Much of it is straight forward but I'm hesitant to dive into the wiring that goes behind the engine to the fusebox/firewall connector. I'm just not sure what I'm getting into, there.
Is this a relatively simple snip and remove operation or is there some major surgery needed?
MiniD is offline   Reply With Quote
Old 10-30-2022, 03:03 PM   #2
chevmn
Re: 1985 C10 with TBI
85 should have an ECM, and probably still electronics (sensors, other controls). If it were me, I would remove the carb, and replace the TBI. Do you have a check engine light? Even though it probably runs better, very likely it is not right if it still has the stock electronics, and missing the TBI. It might have had other work done, but my experience is many think they can simply remove or bypass parts and get by.
chevmn is offline   Reply With Quote
Old 10-30-2022, 05:42 PM   #3
MiniD
I do not have a check engine light. I was worried the fuel pump wouldn't work but it is still doing its thing.
I'm going to convert the electrical system over to a standard truck with no TBI. This will also significantly clean up 35 years of "stuff". I'll have to figure out what to do with the fuel pumps, though.
Old 10-30-2022, 08:35 PM   #4
Just call me Sean
Just call me Sean's Avatar
85 didn't come with fuel injection. Are you sure it isn't wiring for an electronic feedback carburetor?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 10-30-2022, 08:56 PM   #5
MiniD
Yes, I'm sure. TBI. This system was on the truck until earlier this year. A regulator is in place with a return line prior to the carb. The wiring really looks to be factory including the mounting bracket for the ECM and the hole in the firewall (doesn't look cut after paint). The owner that bought it new <reportedly> said something about a TBI test vehicle or something like that. Sadly, he has passed away since. The glove box isn't original, so RPO codes. Overall... I'm not so worried about it. It's impossible to prove and I don't want it, anyway.
Old 10-30-2022, 08:58 PM   #6
chevmn
Sean is correct....if memory serves the first year for TBI on pickups was 87. So it should have a electronic feedback carb assuming this is a factory engine. Probably 305 as the 350 was not available on 1/2 ton until 87 as well.
Old 10-31-2022, 02:04 AM   #7
Just call me Sean
Switching a TBI to carb isn't done by just bolting on a carburetor. It takes a bit more.
Old 10-31-2022, 09:46 AM   #8
cdub2010
The tbi harness is really simple to remove from the vehicle. I believe its not connected to anything else besides tbi, distributor and ecm. Since you have a carb now some one took care of most of the wiring, factory installed or not. Just locate the ecm, a silver box approx 9x6 inches under the pass side dash and remove everything hooked up to it.
cdub2010 is offline   Reply With Quote
Old 11-04-2022, 07:55 PM   #9
MiniD
Not much more. You need to regulate the fuel pressure down and make sure the fuel pump has power. What else would you need in addition to that? Intake, Carb and cam have been replaced.
Old 11-04-2022, 08:01 PM   #10
MiniD
It still has wires going through the back of the engine wire bundle to the bulkhead connector.
I've bought a regular wiring harness for the truck. I'm going to install that and not worry about it. I also bought a new fuel pump for the Holly Sniper that came with the truck.
Old 11-04-2022, 08:08 PM   #11
MiniD
Meant to post this but didn't notice the add attachments button...
Old 11-04-2022, 10:42 PM   #12
Just call me Sean
Carbureted and fuel injected manifolds have a different bolt pattern so the intake is a special expensive one, or change the heads with the intake. Or butcher up a carbed intake to make it fit. No safety for the fuel pump so in an accident you could pump fuel all over the place. Distributor would need to be changed as the computer also controls it.
You should be able to switch to a mechanical fuel pump. The earlier blocks usually just had a block off plate.
Old 11-05-2022, 12:35 PM   #13
MiniD
There's an HEI on it, too. As for the bolt pattern... I'm not sure this speaks to an 85. Just saying.
There was a throttle body on it. It now has a carburetor. I'm not quite sure the point you're trying to make as to that being impossible.
Old 11-05-2022, 01:44 PM   #14
Just call me Sean
I didn't say it's impossible, I'm saying your truck is butchered. Yes this applies to your 85 that's why I'm telling you. If it has center bolt valve covers it has 87 EFI heads, if they're perimeter bolts it has 85 carbureted type heads.
Old 11-05-2022, 09:23 PM   #15
MiniD
Edelbrock makes a carbureted manifold for that, sir. Modifying a carbureted manifold designed for carbureted heads to accommodate the different bolt angle isn't difficult either. There's no butchering required. The conversion is actually quite easy... not difficult or insurmountable.
You sound aggressive or defensive as if this is some kind of competition that you need to win. The truck does not appear to be butchered, at all. It has simply had the TBI removed.
Old 11-05-2022, 11:32 PM   #16
Just call me Sean
So which of those things has been done to your butchered truck? Does it have the expensive manifold (non butchered) or did someone wallow out the holes (butchered)? I never said the conversion was difficult, I don't know where you're getting that from. The fact that you're removing things that you say are factory installed is exactly what butchering is. I was trying to figure out what was done to your truck because it does sound like an interesting truck, so I guess I'm winning at that.
Old 11-06-2022, 12:51 AM   #17
MiniD
Sigh... You're not really here to help. I get it.
