Old 10-29-2022, 10:26 PM   #1
wazzabie
Rust in fuel tank
I pulled the fuel tank and I see some rust. About 15% of the bottom of the tank. Anyone here repaired a rusty tank?
wazzabie is offline   Reply With Quote
Old 10-30-2022, 12:53 AM   #2
bigdaddy4x4
bigdaddy4x4's Avatar
Re: Rust in fuel tank
just buy a new tank they aint worth fixing. a new one is less than 125.00
bigdaddy4x4 is offline   Reply With Quote
Old 10-30-2022, 08:43 AM   #3
cadillac_al
I pulled the sending unit on mine and it was spotless inside. A month later it was leaking. It rusted through from the outside because of the factory skid plate. If the outside looks ok then it's a coin flip. New ones are cheap peace of mind.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-30-2022, 10:53 AM   #4
Dead Parrot
My driver's side tank rusted from the outside in where the straps hold it in place. The inside was otherwise clean.
If money is an issue and the rust is light, make sure your sock is in good shape and install a filter (Fram G3) in the rubber line from the frame to the fuel pump.
Heavy rust = buy new tank. The metal isn't that thick so large chunks of rust mean very thin good metal where the pieces fell off.
Dead Parrot is offline   Reply With Quote
Old 10-30-2022, 07:27 PM   #5
wazzabie
I don't have any rust on the outside. The rust is o the inside of the tank covering about 15% of the bottom inside.
