Old 11-01-2022, 07:43 PM   #1
daves72C10D
daves72C10D's Avatar
Front hard brake lines on a 72
So, the drivers side flare nut is 7/16 and the pass side flare nut is 3/8. How? I have new flex lines but the pass side nut is too small. Anyone got a fix?
Thank you!!!!
1972 Custom 10 Deluxe- original paint, interior- 72k miles
http://www.cardomain.com/ride/2466316
Cheap, Fast or Good. Pick any two.
1990 Eagle Talon AWD
1991.5 W250 CTD
1992 Cushman Truckster- Haulster
daves72C10D is offline   Reply With Quote
Old 11-01-2022, 10:05 PM   #2
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Front hard brake lines on a 72
Thank you!!!!
The left side L shaped line is backwards? I just replaced all the lines on my 72 and was thrown off with a red fitting on the L shaped line. I made the rubber flex line connections first at the caliper and then at the anchor point using the clip to lock it into position. The union is 3/8 and the 7/16 attaches to the line.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-01-2022, 10:08 PM   #3
Ironangel
Ironangel's Avatar
Now you have me wondering if the flex lines are made like that so we dont put the right side on the left? I just went out and looked, the left side is 7/16 and the right side is 3/8...I think they do that so we dont install those banjo fittings wrong and chance tearing a flex line.?
"Two Seventy Two's"
02 3/4 ton Express
Old 11-03-2022, 05:51 PM   #4
daves72C10D
Ok, so I need to find a line that fits the passenger side. Thanks.
1991.5 W250 CTD
Old 11-03-2022, 06:52 PM   #5
pjmoreland
pjmoreland's Avatar
The O'Reilly website lists the right side hose as having a 3/8 fitting.
https://www.oreillyauto.com/detail/c...ake+hose&pos=2
The left side is listed as 7/16".
https://www.oreillyauto.com/detail/c...ake+hose&pos=3
pjmoreland is offline   Reply With Quote
