![]() Join Date: Jun 2019
Intake Plug & GLUE?
Does this plug Glue to the top of this intake hole?
Mine came off when I tore my LS engine down? Suggestions on what to use for glues? RTV?
http://67-72chevytrucks.com/vboard/s...d.php?t=791250 |
BMW & ASE Master Certified
Re: Intake Plug & GLUE?
it was most likely plastic welded from factory and is now broken.
1) maybe clean the bejesus out of it, skuff it up with course sand paper and use a high quality plastic adhesive glue.... what goes there... brake booster is on the back of the intake correct? 2) replace intake
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
I have a spare intake I'd let go for cheap if you want to replace it. Just let me know.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
JB Weld
Find a plug and use a soldering iron to melt it back in place. I have done this many times with no issues. Depending on the size, you could even thread it for a pipe plug and screw in a plug. This is an easy fix.
Thanks guys!
I was thinking JB weld, but I like the soldering iron way, better. Will give that a try!
#7 | |
Thanks, going to try and plastic weld it with the old soldering iron first.
| Bookmarks |
