Old 11-04-2022, 10:38 AM   #1
34GH111
Blew up my rear diff - need rear end ID help - 1970 K10
So I was going down the road about 40 and BOOM, rear differential decided to start trying to eject metal pieces through the housing.
I'm trying to read posts as fast as I can to figure out what I have and what I need but having trouble identifying...here are some pics.
What rear end do I have?
All I have to go on so far is I've got a 1970 K10 with 3.07 gears,
and this number on the axle TDG0313W
and this number on the carrier 3896839
and this hole in the pumpkin!!!
34GH111 is offline   Reply With Quote
Old 11-04-2022, 10:54 AM   #2
34GH111
Re: Blew up my rear diff - need rear end ID help - 1970 K10
Found this great post by LockDoc with axle decodings... based on the axle number I have it appears to confirm that this may be the original axle to the truck? Or at least same year?
http://67-72chevytrucks.com/vboard/s...hlight=3896839
Old 11-04-2022, 01:09 PM   #3
Stocker
20' Daredevil (Ret)
Stocker's Avatar
GM 12-bolt. That's a beautiful truck!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-04-2022, 01:27 PM   #4
HO455
Post Whore
HO455's Avatar
Welcome aboard! Wish it was under better circumstances.
Where are you and that great truck located?
RIP Bob Parks.
Old 11-06-2022, 06:19 AM   #5
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
GM Truck 12-bolt Positrac, excellent rear end and gear for a daily driver. Hopefully the carrier and posi survived. Those T-12's were used in 1/2 ton C/10's until 81. If you cant find a 12-bolt you can upgrade to a Dana 60 or 14-bolt with factory No Spin or Detroit Locker.
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 11-06-2022, 11:44 AM   #6
Accelo
Accelo's Avatar
I own an identical Transmission Jack. Didn't know they made the attachments you have for the differential. Likely handy for transfer-cases also.
If it was me I would replace the assembly. After this stress things are likely bent!
Sounds like this is your goal.
I will qualify this as I have seen amazing repairs with epoxy metal. Mostly when replacement parts were unattainable. If you pull the cover a picture of the carnage would be interesting.
As for the interchange, do the K truck (4x4) have different axle widths like the two wheel drives? Do any of them match the width of the K trucks? Obviously to use one out of the more common 2 wheel drive trucks it would have to be equipped with the rare leaf springs option, if it's a Chevrolet. Or from a GMC where, they all have leaf springs.
Nice truck. Differential only lasted 52 years! Did you put it in four wheel drive and drive it home like I may have. Differential was already dead. Can't hurt it much.
Cheers
Accelo is offline   Reply With Quote
Old 11-06-2022, 04:03 PM   #7
57taskforce
All about them K’s
57taskforce's Avatar
Cheers
Nice carnage!!! GMC’s had coils as an option too. Pretty confident the 67-72 2wd rear won’t work with out more work as the spring perch widths are different between the two. Id find a used housing and swap a new set of gears, and carrier and/or Posi too, if needed and maybe axle bearings and seals if they need it too while you’re there. I realize that’s an expensive list of parts, but in the end you would know exactly what you’ve got as opposed to a swapped in axle of presumably unknown miles/quality of life etc. etc. unfortunately unless you do a re-perch or go to a 8 lug rear axle (sqaure body K30 only 14 bolt FF would be my 1st choice if going this route) than you’ll have to find a 69-72 12 bolt housing to be a direct bolt in. My suggestion would be to look for the last option 69-72 housing and rebuild it before putting it back together.
Tyler
57taskforce is offline   Reply With Quote
Old 11-07-2022, 08:14 AM   #8
Bigdav160
Bigdav160's Avatar
Now's the time to ditch those 3.08/3.07 pair and put in 3.73 gears
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-07-2022, 11:57 AM   #9
34GH111
Thanks for all the help so far...will post pics of the destruction when I have.
I'm in the Fort Lauderdale area. Any suggestions on where to look for a donor rear end? Willing to travel to get it. Or ship.
Yes my preference would be to do a simple direct swap and not modify. I don't mind the expensive list of internal parts - like you said, it would be nice to know for sure what's in there. But having trouble finding the right housing...looking all over on craigslist, FB, etc
So what I'm seeing is I need to find a GM 12 bolt rear from a 69-72 K10 as a 2WD leaf spring axle won't work without modifying mount positions. Is a 4WD GMC 1/2 ton axle also a direct bolt in?
Old 11-07-2022, 12:44 PM   #10
34GH111
I'm seeing that the 73 and later K10 axles have a wider spacing on the leaf springs, is that correct?
Old 11-07-2022, 09:23 PM   #11
franken
Yes, the frames are the same width, but the frame spring perch brackets are bigger.
As I recall the wheel mounting surface (WMS) (think drum face to drum face) is a bit more making the overall track width a bit larger.
BTW, I think I saw a for sale post for a 70 K10 diff here today.
franken is offline   Reply With Quote
Old 11-08-2022, 10:26 AM   #12
34GH111
Thanks - will look back through the parts classifieds and see what I missed. Thought everything I found was old/already sold.
Old 11-08-2022, 08:23 PM   #13
57taskforce
All about them K’s
Yep that is correct the only 73-87(91) rear axle that has the correct 67-72 perch spacing of 40.5” on center is from the 77+ K30.
Tyler
Old 11-10-2022, 10:10 PM   #14
34GH111
So what about 70-71 blazer axles? Are they a direct swap in for the K10 (leaf and shock perches)? Have a line on one and waiting for some measurements...
Old 11-10-2022, 11:08 PM   #15
57taskforce
All about them K’s
Awesome! Yep a 69-72 blazer axle should be a direct fit.
Tyler
