Old 11-04-2022, 05:38 PM   #1
kens65fb
Carb Choke Question
We just installed an Eddelbrock 650 CFM on my buddies truck.
When it starts in the morning the choke seems to work, but the idle is way to slow ( 600RPM) I've read that the high speed idle when the choke first comes on should be about 1200 rpm or so.
I know that the fast idle screw is located beneath the regular idle screw, that is where you can increase the cold idle.
What direction do you rotate the screw to INCREASE idle speed, clockwise or counterclockwise ??
kens65fb is offline   Reply With Quote
Old 11-04-2022, 08:19 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Carb Choke Question
You can download the manual and see on page #9 here - https://www.google.com/url?sa=t&rct=...sRwBEibZZz7Gl1
It's an auto download page, check your downloads once clicked.
Old 11-07-2022, 01:35 PM   #3
Wrenchbender Ret
You turn the screw clockwise to increase the speed.
George
Wrenchbender Ret is offline   Reply With Quote
Old 11-07-2022, 04:55 PM   #4
kens65fb
George
Thanks, I apperciate the response.
