Old 11-05-2022, 06:30 PM   #1
CG
BlahBlahBlah
Windshield trim?
I'm cleaning house and trying to decide which trim is better, shallow trim or deep trim? I need to keep a couple of extra sets (just in case).
Or does it even matter as long as you have the correct gasket?
Old 11-05-2022, 07:05 PM   #2
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
Re: Windshield trim?
mainly just need the correct gasket. Thats the important thing to get the trim to seat correctly in the seal
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 11-05-2022, 08:56 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
I've always found that the stock deep trim is easier to keep in place when installing the windshields. (I install all of my own)
LockDoc
Leon
Old 11-06-2022, 08:22 AM   #4
They say it's best to use the early gasket and the later (deeper) trim. That way you don't have to worry about getting the trim all the way in or worry about it popping out
On the serious side, factory is best and later is preferred.
Old 11-06-2022, 10:16 AM   #5
CG
BlahBlahBlah
Ok a little confused now Tim ... I read on the board that the later trim 71-72 was the 3/8 and the earlier 67-70 was the 5/8.
Old 11-06-2022, 11:33 AM   #6
Grumpy old man
Grumpy old man's Avatar
I think Tim hasn't had enough coffee yet this morning .
The 67-70 deep 5/8 trim used with the Precision WCR - 685 gasket works better .
The 71-72 shallow 3/8 trim uses the Precision WCR - 685 - A , the trim is prone to popping out of the groove when installing .
You Can't mix the year trim and gaskets .
Which ever year trim and gasket is used the trick to avoiding issues when installing is to assemble the gasket and trim and tape it in place and allow it to relax in postion by storing it in a warm place for a week before attempting to install the glass into your truck , The gaskets will seat better with the trim and the windshield opening if it's allowed to stretch .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 11-07-2022, 10:20 AM   #7
Maybe I'm dyslexic . Yep, got that backwards, haven't delved into trim lately. Sorry. Late = shallow/early = late
I just know I have the deeper trim for my trucks
Old 11-09-2022, 03:12 PM   #8
tdangle
tdangle's Avatar
Thanks for the tip, I'll be replacing mine due to leaking in a week or so. My fault due to a lousy install. Do you recommend any sealant? Per the Steel Rubber website they do.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 11-10-2022, 09:28 AM   #9
Grumpy old man
I just install using windex or mild soap water in a spray bottle , NO silicone / NO urethane based products . I've seen where the factory install manual says to use a butyl strip approx 6" from each corner , Trying to use anytype of sealer when installing will just cause a huge mess . Once installed if you find you have a leak I just use a black butyl flow grade sealer , The sealer and dispensing gun are expensive but they work and will last a very long time .
https://sgawinc.com/CRL-Pint-Windshi...t-CRL1716.html
Old 11-12-2022, 07:14 AM   #10
The factory did use butyl sealer in the bottom corners and a white sealer in the top corners. I don't know how they did it w/o making a mess
