Old 11-06-2022, 11:14 PM   #1
DINS 1
DINS 1's Avatar
89 2wd cab to 90 4x4 frame.
how much wiring do i have to do to make the 89 2wd cab work on the 90 4wd frame both are 5.7 motors both are manual window lock and A/C trucks. the 89 has a 700r4 and the 90 has ath400.. i know i will have to move the 4wd shifter. that is where the wiring needs to be added to the 89. something might have to change for the transmission.
Wade
72 3/4 ton 4x4 Burb 6.0 LS Long term project
2024 Silverado CC SB DURAMAX.
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 11-07-2022, 11:56 AM   #2
Re: 89 2wd cab to 90 4x4 frame.
Me, swap the wiring harness from the 4wd cab to the new cab. Not sure, there might be a high humb for the 4wd, which is not in 2wd. Never had a 4WD version of these trucks, so not sure.
Old 11-08-2022, 07:44 AM   #3
I can't say for sure because I've never tried this. But the only thing I can think of is the differences in speed sensors on transmission, if any difference at all. The transfer case is manual. The only thing electric is the indicator. I'm sure that's simple wiring if you don't have the harness. I don't know about floor hump, but you have both to check
Old 11-10-2022, 12:28 PM   #4
1976gmc20
The front axle connector is electric, run off a switch on the TC lever.
Or you could just lock it in permanently with a 1" piece of 3/4" plastic pipe like I did. Just like running with the hubs always locked in, or like my old jeep that turns all the time anyway from the factory.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
