11-07-2022, 05:45 PM | #1 |
Headlight relay
I was reading this post http://67-72chevytrucks.com/vboard/s...highlight=horn and have put this on the list of things to do to my truck. Saw this on lmc truck https://www.lmctruck.com/1967-72-che...dlight-harness
Has anyone used the one from LMC?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-07-2022, 06:45 PM | #2 |
Who Changed This?
Re: Headlight relay
I got mine from there. It's working fine, so far. It's been about 1.5 years since installation.
11-07-2022, 06:48 PM | #3 |
Re: Headlight relay
Yes, same as mine. Here is my thread about it
https://67-72chevytrucks.com/vboard/...dlight+harness Makes not only headlights brighter, but all other lights also |
11-07-2022, 07:19 PM | #4 | |
Re: Headlight relay
Thanks!
11-07-2022, 08:33 PM | #5 |
Re: Headlight relay
Install is very simple. No cutting any wires. Just mount the relays where I did or on PS of core support if you want. Simple install steps come with harness
Mount relays (I drilled 2 holes in fender lip) connect harness + wire to the + buss on PS fender by battery screw ground wire to fender unplug PS headlight and plug it into harness (marked plug) plug the harness plug into PS headlight run harness under core support to DS Unplug DS headlight (it will be left unused) plug harness plug into DS headlight Open beer, admire work I have one of these in my 67 Camaro also (different brand). All the older cars had full headlight draw go through the switch, so this mod is beneficial to any car/truck of that era |
11-08-2022, 10:09 AM | #6 |
Re: Headlight relay
These kits are great. I would find one that has the following: at least 2 relays, 1 for high beam and 1 for low beam. Real high quality 5-pin relays made by Bosch, Hella, or Tyco. No offshore China relays (sealed Delco oval relays would also be acceptable-but not square). Actual real relay sockets, if it just has female spades for the relays, pass. Would be nice if the sockets had a mounting tab. Good quality wire and nice loom. Be sure to create a rock-solid ground. You are replacing-or at least supplementing-the factory ground for the headlights with this harness. If you do that you should have something that will last another 50 years.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-08-2022, 10:25 AM | #7 |
Re: Headlight relay
I wish there was one of these harness that is made in USA, maybe there is.
The one I got for my Camaro from Speedway was in a plastic zip loc bag, no printed instructions but these things are frankly self-describing on how to install. I assume someone made the Speedway one here....but were "offshore" parts used, IDK. So far, for me both the Speedway one and the LMC one (which is clearly packaged as being from China) are working. YMMV |
11-08-2022, 01:00 PM | #8 |
Re: Headlight relay
Those kits seem to be nice, but you are adding 20 feet of extra wires around the radiator support. I added one 12 v wire from the battery junction block across to the driver side fender. I wired the relays like was described in the first post of the link provided by the OP in this thread. Less complicated and far fewer excess wires.
'67 GMC 2500, 292, 4spd, AC Last edited by RichardJ; 11-08-2022 at 01:07 PM. |
11-08-2022, 01:21 PM | #9 |
Re: Headlight relay
well a few ways to skin this cat, rolling your own setup is fine Not sure about your 20' math of extra wiring.... with a harness pre-made you are capturing the high volt, 12vdc, from the buss terminal on PS fender next to battery so that eliminates it coming all the way from the headlight switch to both L&R headlights but the wire running across the core support, IMHO is shorter overall of the 2 eliminated from headlight switch IMHO either way a non-issue which method you chose. The main reason is to relieve the full draw load of headlights from the headlight switch itself and turning it into a relay trigger to activate the buss bar +12vdc source for headlights |
11-08-2022, 01:44 PM | #10 |
Re: Headlight relay
It looks like 20 feet to me and this is just for a two light chevy.
The other link in the first post for LMC shows the guy removing the battery, battery box and loosening the radiator. In the end, they ended up with the battery wiring in the screen capture shown below. Sorry, I don't want any of that.
'67 GMC 2500, 292, 4spd, AC |
11-08-2022, 02:19 PM | #11 | |
Re: Headlight relay
11-08-2022, 02:34 PM | #12 |
70+ ( Old Skool Club )
Re: Headlight relay
With my first truck I went to the junk yard and gota couple realys froman old Dodge Caravan and with Instructions from MAD Electricals site and did the headlight upgrade bt this time I bought the American Autowre Kit, in 2018, and havent installed it yet.
https://www.americanautowire.com/sho...ncer-relay-kit
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-08-2022, 04:15 PM | #13 |
Almost Satisfied
Re: Headlight relay
If one springs for the Holley retro headlights do those need this relay option?
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
11-08-2022, 05:12 PM | #14 |
Re: Headlight relay
11-08-2022, 05:25 PM | #15 | |
Re: Headlight relay
I did remove the 2 radiator hold down brackets to run the harness in the core support but never had to move the radiator itself. Removing battery makes it easier to unplug PS headlight and access the AUX buss connection These headlight relay harnesses are very simple, and one can make their own. AAW stuff, IMHO, is always solid stuff. There are also a few independent "wire guys" who make this stuff. Gary @ innovative wiring makes great stuff. IDK if he does make headlight harness but his (battery cables, EL fan relay harness, MAF extensions, etc) are excellent quality |
11-08-2022, 07:22 PM | #16 | |
Re: Headlight relay
If running stock headlights or H4 upgrade, relay setup is highly recommended. It's worth mentioning that the relay setup does take the load off the headlight switch so regardless which headlight you run (stock, H4 or LED), it's an upgrade.
66 GMC Suburban Custom 66 Chevy K10 Suburban Last edited by Southcity; 11-08-2022 at 07:30 PM. |
11-08-2022, 07:40 PM | #17 | |
Re: Headlight relay
Thanks!
11-08-2022, 08:23 PM | #18 |
Re: Headlight relay
K10 = Holley Retrobright
GMC = United Pacific Both perform great but I'm liking the Retrobrights for their stock-lens look
66 GMC Suburban Custom 66 Chevy K10 Suburban |
11-09-2022, 07:34 AM | #19 | |
Re: Headlight relay
https://www.amazon.com/IPCW-CWC-7006...01OMEPEU&psc=1
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
11-09-2022, 08:04 PM | #20 | |
Re: Headlight relay
Original headlights work for me. |
11-10-2022, 12:31 AM | #21 |
Who Changed This?
Re: Headlight relay
Were halogen headlights OEM in '67 to '72? I wear glasses, too.
11-10-2022, 09:33 AM | #22 | |
20' Daredevil (Ret)
Re: Headlight relay
I wore glasses from age 7 until I got contacts at 19. Since cataract surgery several years ago, I now just use readers. Improved lighting has always been a good thing for me, no matter my age or vision correction.
11-10-2022, 12:22 PM | #23 |
Re: Headlight relay
Halogens became popular in the early to mid 80's.
I can't see any advantage to using relays with LED lamps. George |
11-10-2022, 12:38 PM | #24 |
Re: Headlight relay
Some LED set up's pull decent amperage. Mainly in headlight applications, some sort of load to build up heat is used to help keep them from fogging or icing up in poor weather conditions.
11-10-2022, 06:14 PM | #25 |
Re: Headlight relay
Thanks for the ideas. I will look into both the LED headlights and the relay conversion.
This is why this board is AWESOME!!
