11-08-2022, 06:34 PM | #1 |
Rear gears
After driving my '71 Suburban with the original warmed over 307, 700r4, and 3.07 ring and pinion gear for a while, I've decided I need to change rear gears. At 70mph, it's only turning 2000rpm's. Looking at the vacuum gauge, it's struggling at that low rpm. If I had a bigger engine with more torque, it wouldn't be a problem, but the 307 wants and needs more rpm's. They sell a 3.42 and a 3.73 for the 12 bolt truck rear with the 3-series carrier. I want to maximize fuel economy, but would the 3.42 still be too low? Opinions wanted.
11-08-2022, 06:49 PM | #2 |
Re: Rear gears
I have 3.42's in my 68, it originally had 3:73's and my small block was a humming on the highway, but I also am running a M21 Muncie 4 speed. I like the 3:42's. I think you need to google one of those rpm calculators where it asks for your tire height and current specs and then see what the 2 options give you and then run that rpm and see where your gauge is at.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
11-08-2022, 07:44 PM | #3 |
Re: Rear gears
Its not a 67-72 Chevy truck but I have the 3.42s in my 01 GMC Sierra with the 4l60e. At 75 the rpms are right at 2100. Been a great highway gear with best of both worlds. Good mileage and power. The plan is to do the same with my 68 Chevy once I get to that point but POSI
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-09-2022, 01:34 AM | #4 |
Re: Rear gears
Tire size plays a huge factor.
11-09-2022, 07:49 PM | #5 |
Re: Rear gears
I have 3.73's paried with a 4l60e and a 700r4, I really like that combination.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e 1970 Chevrolet K5 Blazer - Project 1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4 1969 GMC Suburban - 5.3 LS, 4L60e |
11-09-2022, 08:38 PM | #6 |
Post Whore
Re: Rear gears
As an apples to pears comparison. GM put 3.42 gears in most 2wd S-10's. So my 91 Blazer with the 160 hp 4.3 and a 700R4 weighting 3900 lb is a close match to a 307 C10 with a 700R4. I don't believe you would be unhappy with the 3.42 gears. Plus the 25 to 50 mph acceleration is really snappy.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-09-2022, 08:54 PM | #7 |
Re: Rear gears
vince what is your rear tire diameter? that will help the conversation.
11-10-2022, 07:36 PM | #8 | |
Re: Rear gears
11-10-2022, 07:36 PM | #9 |
Re: Rear gears
[QUOTE=jocko;9142601]vince what is your rear tire diameter? that will help the conversation.[/QUOT
Rear tires are 27" dia. |
11-10-2022, 08:13 PM | #10 |
Re: Rear gears
Here are the numbers to help you choose. I think 3.73 or 3.42 would both be fine for cruising at >60 mph on the highway. If you want a little more accel than that 3.07, both options are improvements, especially with your 700R4, but 3.73 would be the way to go if acceleration is important to you.
11-10-2022, 08:39 PM | #11 |
Re: Rear gears
3.73 ratio will be the best for your needs
11-11-2022, 12:16 AM | #12 | |
Re: Rear gears
