11-08-2022, 07:49 PM | #1 |
Good Quality Hei Distributor
I am making of list of part to swap on my 68 SWB and a good quality HEI is on the top of the list. It currently has a ebay special that I want to get rid of. I have shopped around and found distributors from 100-400$ but before I buy anything I wanted to ask here first. Looking for good quality and reliability.
Thanks in advance!!
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
11-08-2022, 08:58 PM | #2 |
Who Changed This?
Re: Good Quality Hei Distributor
I have a Mallory version that looks like the stock GM unit. It's been in use since '01.
11-08-2022, 09:50 PM | #3 |
Try one from here.
I’ve heard they will set up a custom curve too. https://performancedistributors.com/ |
11-08-2022, 10:59 PM | #4 | |
Who Changed This?
11-09-2022, 08:37 AM | #5 |
I would find a used GM one and buy a new Delco module for it. The stock ones are still out there.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
11-09-2022, 09:08 AM | #6 |
So far, OEM is all I've ever used. I've never had problems with one, but I assume parts are available to repair when needed. As far as curve goes, there are weight and spring kits to deal with that.
11-09-2022, 09:55 AM | #7 |
Chevrolet Performance HEI
19432312 |
11-09-2022, 10:48 AM | #8 |
I have done 2 pickups, both with stock salvage distributors. I did have an issue where one was worn to the point I had to replace the pins, but I believe I found the pins as well. They are out there. I purchased one from a individual that had the dist laying in the bed of another truck he was selling for $20. If you remove the module, be sure to apply the heat sink compound or you will be replacing it again soon after.
11-09-2022, 11:14 AM | #9 |
One of the First
I've have always ran Davis Unified Ignitions (DUI):
https://performancedistributors.com/ The small head electronic ignition is perfect for 67-72 4x4's.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
11-09-2022, 12:08 PM | #10 |
Post Whore
check out this guys threads:
https://67-72chevytrucks.com/vboard/...postcount=4182 https://67-72chevytrucks.com/vboard/...postcount=4168 https://67-72chevytrucks.com/vboard/...postcount=4169 https://67-72chevytrucks.com/vboard/...postcount=4170 |
11-09-2022, 01:10 PM | #11 |
Harley 1969 Chevy C-10 Long Bed, 350cid, 700R4 |
11-09-2022, 01:19 PM | #12 | |
Who Changed This?
11-09-2022, 02:50 PM | #13 |
OOhh ouch. Sorry bout that.
11-09-2022, 06:37 PM | #14 |
Ive been looking into Progression Ignition. It's essentially a Bluetooth distributor you can set up with your phone.
It's got some fancy features like the ability to lock it out with a pin number, so it'd have to be towed to be stolen. It has a map sensor in the housing so it has infinitely controllable vacuum advance, and on the fly you can change your advance curve with presets or completely manually using the app. You set static timing to 10 degrees, then the app takes over, so you can essentially have easy starting AND high timing at idle if that's what your engine wanted. It isn't something you can run down to the auto parts store and pick up spare parts for, but it looks like a quality piece, with reviews to match. |
11-09-2022, 08:08 PM | #15 |
^^^That sounds badarse. Very cool and genuinely useful.
$500 |
11-13-2022, 12:58 PM | #16 | |
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
11-13-2022, 05:44 PM | #17 | |
11-14-2022, 11:55 AM | #18 |
11-14-2022, 01:43 PM | #19 |
My 68 had a GM HEI in it when I bought the truck. I took it out and tossed it, went back to points. Have had more issues with HEI and Pertonix like stuff.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
11-14-2022, 02:19 PM | #20 |
I have an update. I reached out to a guy I know that works the parts counter at a Chevy dealership and he was able to order a new HEI with cap and coil with a %30 discount. Should be arriving tomorrow. Thanks for all of the suggestions. Once I get it I will post pics.
11-15-2022, 08:17 PM | #21 |
I have a progression ignition and it is great. Did have a msd streetfire did the springs and weights big pain now all the changes on my phone are done on the fly.
