Old 11-09-2022, 11:36 AM   #1
scott123
Brake plate from a member
Getting ready to put a firewall mounted disc brake set up on the 1950.
I got this plate from joedoh.
I am not sure if he is a rocket surgeon or a brain scientist but this plate he makes is kick ass easy.
Bend and tack then bend and tack.
I am not sure I did it as designed but it turned out perfectly workable.
Nice piece.
Scott
scott123 is offline   Reply With Quote
Old 11-09-2022, 02:43 PM   #2
joedoh
joedoh's Avatar
Re: Brake plate from a member
hahaha rocket surgeon sounds like a good career path
glad you like it!
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 11-09-2022, 02:57 PM   #3
mr48chev
mr48chev's Avatar
That's a firewall saver. Back in the 70's when the hot lick was to stick the master cylinder on the fire wall of your hot rod I saw a number of cracked out firewalls because the guy who stuck the car together (can't call them builders) just drilled holes in the firewalls and hung the pedal and master cylinder.
My ongoing truck projects:
Old 11-10-2022, 10:52 AM   #4
Rickysnickers
That's a very good review. Russ makes some nice things. Do the rest of the board a favor, and Russ, and write a nice review here too, so that it gets more traffic, please.
https://67-72chevytrucks.com/vboard/...play.php?f=238
Old 11-10-2022, 08:22 PM   #5
scott123
Copy that.
Just made the post.
Hope it is correct.
Scott
Old 11-11-2022, 10:32 AM   #6
Rickysnickers
Perfect!
Old 11-11-2022, 03:27 PM   #7
joedoh
joedoh's Avatar
thanks fellers!
