Old 11-10-2022, 03:10 PM   #1
44SAA
Removed Thermostat- Coolant Flush Hot
Performing a coolant flush and removed the thermostat. After bout 5 minutes the temp gage on the truck was pegged in the danger zone. Am I missing something? Will idling without a t-stat cause high temps? Interestingly when I removed the peacock the water was cool. Upper rad hose was scalding hot. Confirmed water was moving inside the rad as well. Thank you
44SAA is offline   Reply With Quote
