11-11-2022, 12:25 PM | #1 |
K25 Fuel Gauge Problem
My '68 3/4-ton 4wd came factory equipped with saddle-bag tanks in addition to the standard tank. Recently the fuel gauge had begun reading high (3 o'clock position) for the saddle-bag tanks only. The standard tank still reads correctly. I understand that this symptom indicates a ground problem, but since it affects both tanks I was hoping someone could point me to the likely location of the fault. There's a foot of snow on the ground and I don't relish rooting around trying to find it. TIA.
11-11-2022, 12:44 PM | #2 |
Re: K25 Fuel Gauge Problem
I don't think I've ever seen this year saddle tanks with senders. Just a hand valve on the floor and you drove until the engine chugged and switched the valve
11-11-2022, 01:01 PM | #3 | |
The Older Generation
Are they in bed tanks or bolted to the frame underneath? Since it is affecting only those tanks I would think it would be the ground from the engine to the frame or from the frame to the bed. The first thing I would do is to run a wire from the NEG battery terminal to the frame and see what that does. You could use a heavy wire with alligator clips on both ends or a jumper cable to test that. If no change go from the NEG battery terminal to the bed. Just make sure where you connect the wire/cable is bare metal on both ends.... That way you wouldn't have to be crawling around underneath trying to figure things out. LockDoc
11-11-2022, 01:14 PM | #4 |
11-11-2022, 01:16 PM | #5 |
11-11-2022, 01:23 PM | #6 | |
11-11-2022, 02:05 PM | #7 | |
I don't know how those are wired with the switch on the dash. You will have to see if you can find a wiring diagram for it. That might be a challenge.... LockDoc
11-12-2022, 02:19 PM | #8 |
Just curious is a K25 different then a K20?
69 K-20 cloned to a 67 with front clip and some other stuff. 383 .040 over Crane roller cam lifters and rockers ,1.6 intake ratio, Open chamber heads, 9.5-1 compression ratio, 2.02 intake valves , Edelbrock performer Air Gap manifold Carter AFB performer 750cfm, MSD ignition, SM465 NP205 4.10 gears: |
11-12-2022, 05:41 PM | #9 |
All are k20 no k25
11-12-2022, 05:43 PM | #10 |
Thats a aftermarket auxiliary gas tank there so you will have to sort out how the po did it
11-13-2022, 12:33 AM | #11 |
15 or 1500 is 1/2t and 25 or 2500 is 3/4t. Standard badging for GMC.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
11-13-2022, 01:48 PM | #12 | |
Okay, now I get it Thanks
12-03-2022, 03:10 PM | #13 |
Once the snow melted off I was able to crawl under the truck. Lo and behold! There was a broken wire right next to the fuel valve/tubes. Spliced it and all was good.
After looking at the installation of the fuel tanks, I believe they were a dealer add-on. I was told the truck was originally ordered in Yreka, CA as a plow truck. It has 4.56 gearing and 80 lb. lead weights just inboard of the rear wheels. |
