11-12-2022, 08:52 PM | #1 |
6-Lug Rear Disc Conversion kit?
Is the a Company/Vendor that makes a 6-Lug Rear Disc conversion kit?
I’ve looked high and low, but have only been able to find a few 5-Lug kits. As an alternative, would a set of brakes from a newer truck work? I know I’d have to cut and weld the brackets from the new axle to the old, but having never done, or even seen this done. Has anyone out there ever done this? |
11-12-2022, 08:56 PM | #2 |
Re: 6-Lug Rear Disc Conversion kit?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
11-12-2022, 09:10 PM | #3 |
I believe this thread should help: https://67-72chevytrucks.com/vboard/...d.php?t=637489 Captainfab has a variety of bracketry solutions
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
11-13-2022, 09:16 AM | #4 |
Thank you for all three responses.
It looks to be more simple than I thought, with no welding involved. I’m thinking about getting another complete rear ended, and doing the conversion on the bench, then do the swap out. |
11-13-2022, 12:55 PM | #5 |
Here's another
https://azproperformance.com/collect...-kit-63-87-c10 |
