11-22-2022, 05:34 PM | #1 |
C10 crossmember question
I have an 81 C10 short box pickup that I will be putting an LQ4 6.0 LS and 4L80 trans. into... will the stock trans crossmember work or will I need a different crossmember?
IF I need a different one, what crossmember should I buy? RIZ
RIZ 81 C10 short box 82 K5 Blazer |
11-23-2022, 08:58 PM | #2 |
Re: C10 crossmember question
nobody ????
11-24-2022, 06:20 AM | #3 |
67-72 parts collector,…
Go follow this guy on YouTube.
He has several videos on LS swapping a squarebody truck. https://youtu.be/3BRI84MXS90 You can also ask your questions in the LS section,… https://67-72chevytrucks.com/vboard/...play.php?f=206
11-24-2022, 01:18 PM | #4 |
You can slide the cross member back, and redrill holes.
I bought one of the adjustable versions with the double hump that I am disappointed in, and will just fab up something nicer when I get around to it. |
11-24-2022, 07:01 PM | #5 |
Some of these trucks have a crossmember that drops on the driver side and some are the "butterfly models.
driver drop https://www.ebay.com/itm/22523006938...xoCPC0QAvD_BwE butterfly style https://www.ebay.com/itm/37424242574...Bk9SR_6C6L2VYQ get one for your year of truck might want to consider one of these https://www.ebay.com/itm/37432045390...Bk9SR7L9gb6VYQ
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
11-24-2022, 07:45 PM | #6 |
thank you......... i will use the ls section from now on.
11-30-2022, 10:53 AM | #7 |
Who's bracket if you don't mind me asking?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-30-2022, 12:13 PM | #8 |
Some questions can be answered in either section. No harm or foul utilizing a different section of the site if the question asked goes unanswered or not answered within your time constraints.
11-30-2022, 02:47 PM | #9 | |
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 11-30-2022 at 02:57 PM. |
11-30-2022, 09:28 PM | #10 | |
Will send you a text. Bubba |
12-01-2022, 02:40 PM | #11 |
Does he make them for 8L90s?
12-16-2022, 02:32 PM | #12 |
Not sure if you found the answer you are looking for but I have an ‘85 with an ls1/4l80e. I hated the factory cross member. Some of the bolts are under the body/on top of the frame, it’s odd shaped for the one exhaust pipe to clear….
I used one from TejasSteelWorks or something like that. I believe I have an old build thread on here that will have pictures
1964 Coupe Deville(cruiser) 1966 Chevy II Nova 2door Hardtop 1985 C10 LS1/4l80e, Ridetech coilovers,22”Coys 2019 F-250 Platinum-Deleted/Carli Supension 37” MT’s 2000 Trans Am WS6, LS1/T-56, too many mods to list |
12-18-2022, 01:50 PM | #13 |
