Old 11-26-2022, 12:21 PM   #1
3x2GTO
differences in steering column shafts
I see some columns with a splined end and some made to accept a squared shaft. Is this a year to year change or maybe the difference between a 4wd and 2wd column? Here's what I have, it's supposed to be from a 78-79, and I'm wanting to install it in my 76 2wd pickup. I'd like to know if it'll fit, before I take my steering shaft out. Thanks!
3x2GTO is offline   Reply With Quote
Old 11-26-2022, 12:32 PM   #2
85burb
85burb's Avatar
Re: differences in steering column shafts
The 78 I’m working on has a splined shaft. I’m pretty sure they changed to that style later on like 79 and newer.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 11-26-2022, 12:38 PM   #3
3x2GTO
So it's not a 2wd versus 4wd thing? Thanks!
Old 11-26-2022, 02:35 PM   #4
85burb
85burb's Avatar
As far as I can find they are just year specific. Don’t think 4 we makes any difference.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-26-2022, 04:26 PM   #5
3x2GTO
Thanks!
Old 11-26-2022, 09:58 PM   #6
85burb
85burb's Avatar
Your welcome. Just went though this a while back. I thought they were all the same and the Jeep steering shaft fit all squares. I was wrong and had to make a shaft work and ended up spending as much making the Jeep shaft work as buying the Borgeson one.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 11-26-2022, 10:23 PM   #7
kipps
Which does the jeep shaft fit? The square style, or the splined style? Which style came before 1979, and which came after?
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
Old 11-27-2022, 01:19 PM   #8
Pontiac1976
Pontiac1976's Avatar
This tilt should fit 73-83 as the w/wiper switch on dash w/high beam switch on the floor. I have some 87 that are still squared shaft, The bell cover top area on 73-77 column are splined and bolt clamps on the side spline notch.
Whereas the 78-91 column bell cover top area are D shaped and bolt goes throw the center. You should be able to see what one you have.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 11-27-2022, 10:24 PM   #9
85burb
85burb's Avatar
The xj steering shaft only fits the square shafts. I bought a steering shaft for a 91 jeek Cherokee.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
