Hubcaps??
Are these hubcaps reproduced by anyone? Mine are kinda beat up.
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
Roadtrip!
![]() Join Date: Feb 2003
Re: Hubcaps??
Nope, and nice used ones are not usually very cheap.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
![]() ![]() Join Date: Sep 2008
Re: Hubcaps??
Somebody here restores them.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
![]() Join Date: Dec 2017
Re: Hubcaps??
Here is a representative photo (from a sold set of some K20s), but it has "brothers" in line for similar treatment.
![]() Join Date: Aug 2018
Re: Hubcaps??
It’s really easy to do yours self with some work.. I polished mine up and repainted.
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US Last edited by DA71Grande; 11-28-2022 at 05:37 PM. Reason: . |
![]() Join Date: Jan 2012
Re: Hubcaps??
Great looking paintwork! Lots of times you can see where paint has slipped under the mask material but I don't see that on yours. What method did you use for masking? Any recommended tips or strategies on achieving great results like you did?
![]() Join Date: Jul 2001
Re: Hubcaps??
Gonna' follow along on this for the tips and info on the restore. I have a set of stainless 1/2 tons for my K10 that need that badly. Getting decent, crisp paint lines at the moment kinda baffles me,
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#9 | |
Re: Hubcaps??
There are still some spots where the paint bled through just can’t see them in the picture. I spent a lot of time preparing (polishing) and cleaning up after removing the tape. I used a good quality 1/4 automotive tape to outline the edges then used the blue painter paint to cover the rest of the hubcap. For paint I used the VHT epoxy doing very light coats let dry in between coats to help prevent bleed through, after removing the tape just clean up any bleed through then I re-polished the hubcap to smooth out the edges. If you have a smaller polisher it makes simple work to get these cleaned up. this is what I have https://www.milwaukeetool.com/Produc...shers/2438-22X
Doug ![]() 71 Sierra Grande C25 16 Sierra 2500HD All Terrain 23 Chevy Tahoe Z71 https://paypal.me/digdug7131?locale.x=en_US |
#10 | |
![]() Join Date: Feb 2009
Re: Hubcaps??
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Who Changed This?
![]() Join Date: Jan 2013
Re: Hubcaps??
Those are some nice hubcaps chevmn, but a set like like that would put the rest of my truck to shame. It would be like painting one wall in the living room.
Re: Hubcaps??
IMO, the stainless versions are the easiest to restore, much stronger metal and usually found with minimal dings, the original issue chrome over brass versions are almost impossible to restore, they are notoriously weak, crack and dent extremely easy. (What was GM thinking in this era
#13 |
Re: Hubcaps??
Thanks Doug. Did you use any etching primer before paint or scuff the metal up lightly to increase adhesion of the paint? I've heard others recommend it but was suspicious that the factory would have taken such measures and the paint seemed to adhere just fine.
#14 |
Re: Hubcaps??
Did do a little scuffing with some fine steel wool, that epoxy paint didn’t require any primer and has help up for 3yrs now
#15 |
I have the 73 through 76 stainless style hubcaps but, I didn't want to spend the money to track down some really nice painted ones. So I took all four of my decent ones to a sandblasting booth and blasted all of them on the outside only, then I shot them with a gloss black, taped all of the areas that were to remain black with pinstriping tape (that was a long tedious process lol), scuffed the rest of the areas with a Scotch-Brite pad then I cleaned them up and shot them with a coat of General Motors Summit White and to add a little Touch of Class I painted the inside of the bow ties Mopar B5 blue.
