Old 01-05-2004, 01:08 AM   #1
littlee_domn8r
AKA "Hurricane Hank"
littlee_domn8r's Avatar
swapping steering column on 63 GMC
Has anyone ever swapped in a later steering column into their truck? I would like to do this since I cannot get the GMC turn signal switch. Any idea what would be the easiest to swap? I've checked into the ididit columns, but they just are not in my budget. Any help would be appreciated.
"looking back, knowing that you gave it your all.... win or lose, you finish a Champion" Dale Earnhardt
"They say hard work never killed anyone, But why take a chance?
63 GMC C10 Custom LWB 355/350 AT
00 Chevy Silverado 1500 base V6/AT
07 Chevy Monte Carlo SS 5.3 V8
littlee_domn8r is offline   Reply With Quote
Old 01-05-2004, 06:41 PM   #2
Iron-Butt
454 club
Iron-Butt's Avatar
I used a 67 or 68 auto tilt column from a motorhome in mine. it works great. I have another one for $150.00 plus the ride.
David
1965 Chevrolet c-10 454 automatic Custom bbw swb.
1965 Chevrolet C-10 swb (Sold)
1963 Chevrolet C-10 6 Cyl automatic with dual exhaust, pb, ps and 17's.
R.I.P "I will miss you.
1967 Chevrolet C-10 6 Cyl Custom lwb
1939 Chevrolet Coupe, 350 v8 automatic.
1935 Chevrolet 2 Dr Standard in the works.
2015 Harley Davidson Street Glide.
2023 Chevrolet Stingray Z51 Convertible.
I never want to grow up.
Iron-Butt is offline   Reply With Quote
Old 01-11-2004, 10:17 PM   #3
cochran63
cochran63's Avatar
i used a 72 tilt column in my 63, but it took a while to figure out the wiring. The columns in the early to late 70's vans are nearly identical to the 72 truck columns but they can be bought for a song
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 01-13-2004, 09:17 PM   #4
littlee_domn8r
Thanks for your info guys! I'll keep your column in mind ironbutt, but I was hoping to find something closer to home. How much modification did you have to do to fit that.
Cochran, I have an automatic, is that what you have? Did you have to do any modification?
Thanks again for your help!
Old 01-17-2004, 12:00 AM   #5
cochran63
cochran63's Avatar
mine is an automatic also, it bolted right in. the only modification i had to do was wire my 63 plug in place of the 72 plug on the harness
Old 01-20-2004, 07:58 PM   #6
littlee_domn8r
Turn signal switch for GMC
I checked with a couple of local parts dealers who now claim they can get me the GMC specific switch without the bearing for $140!! If they actually can get the right switch, I'll post it on the board in case anyone else is in need of one. Keeping my fingers crossed!
Old 01-20-2004, 10:55 PM   #7
cochran63
cochran63's Avatar
that sounds pretty steep. but probably cheaper than an accident or a ticket.
Old 01-23-2004, 12:38 AM   #8
littlee_domn8r
To heck with the local parts guys. Brothers carries the switch for $69.95 with the bearing! Mine should be here Tuesday. I can't believe I've anguished over what to do for the last year because I could not get the GMC switch. Just when I had talked myself into the column swap, the switch is available again. I still won't believe it until I can see it with my own eyes though. If anyone needs a factory switch for a 64 to 66 chevy or a 65 to 66 GMC, I have a brand new one for sale. I paid $75 for it 2 years ago. Thanks for all the help and info, even if it ended up a waste of all our time.
