Old 12-01-2022, 12:52 PM   #1
brown7373
brown7373's Avatar
Rough idle at start.
I continue to have a ridiculous idle on a cold start. I live in south Florida, so I don't mean freezing temps, just sitting over night. It is a crate 350 engine 350/290 4 bbl Q-jet. It seems like only running on 1/2 the cylinders. But If I put it in gear it idles perfectly. Once it gets a little heat in the engine it runs fine. Carb has been rebuilt and it and the choke function as designed. Oh, and it is lucky to get 8 mpg. The original engine got 11-12 mpg. I have heard I need a different torque convertor, but that would have nothing to do with the idle. And once started, and warmed just a tad, it will continue to run fine all day long.
brown7373 is offline   Reply With Quote
Old 12-01-2022, 01:02 PM   #2
HO455
Post Whore
HO455's Avatar
Re: Rough idle at start.
Can you post a photo off the carburetor with the air cleaner removed just after starting it cold? That will help us determine what the issue may be. If you can frame the photo like this one it would be great.
RIP Bob Parks.
Old 12-01-2022, 02:11 PM   #3
brown7373
brown7373's Avatar
This is the picture after starting. Ther engine is running and kicked off fast idle.
Old 12-01-2022, 02:18 PM   #4
weq92f
weq92f's Avatar
Flip fa ya...
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 12-01-2022, 03:16 PM   #5
HO455
Post Whore
HO455's Avatar
It appears that the fast idle cam is in the midway position. Which is good. Meaning that you should be able to turn the fast idle screw in and raise the idle to help smooth things out.
First photo see your fast idle cam position.
Second photo see the cam completely down.
Fast idle adjustment screw is circled in last photo.
Try turning the fast idle up before changing other settings. The RPM should be in the 1000 to 1200 range.
RIP Bob Parks.
Old 12-01-2022, 03:45 PM   #6
brown7373
brown7373's Avatar
I'll give that a try.
Old 12-01-2022, 05:39 PM   #7
LS short box
Maybe a bit too much choke pull off at cold start?
LS short box is offline   Reply With Quote
Old 12-02-2022, 12:37 PM   #8
leftybass209
leftybass209's Avatar
I agree that starting with the carb fast idle is most logical. Most quadrajets just need the proper love and setup. However, there's a whole other list of things just to consider after your rough idle is sorted...
These crate motors are really low compression. They seem to like a lot of timing... in the 14-16+ range i've found after messing with 3 or 4. The engine break in instructions call for weirdly low static timing, and no vacuum advance. Great in theory for racing, and punishing for fuel mileage.
The cam in that 290hp motor is nearly too much for the low compression, and i'd argue the lobe centerline is all wrong as well for the compression.
If the throttle shafts weren't rebushed on that quad, then there may be a vacuum leak around the throttle shaft. Small vacuum leaks may seem like they iron out after a motor warms up, but they can wreak havoc on a cold motor
leftybass209 is offline   Reply With Quote
Old 12-02-2022, 03:12 PM   #9
Steeveedee
Who Changed This?
Steeveedee's Avatar
Truth, about those little vacuum leaks. I bought a '69 Skylark years ago for the engine and trans for my '68 Skylark. The guy had done all kinds of stuff to it- HEI, rebuilt the carb, etc. I drove it home, and when troubleshooting it later I discovered the vacuum line for the AC/heater control not connected to the nipple on the back of the carb. Couldn't hear that leak, but man it sure smoothed out the idle when I connected it.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
