SBC Engine numbers
I have a crusty engine in my 1965 C10 and having a heckofatime finding what it is and if I keep it old school or trade it for a complete LS 5.3 / 4L60E setup a guy wants to trade.
I'm assuming the 1st couple numbers but what I can read is 70010 And under the alternator is two sets of numbers as follows: V0429TDB C8A168256 that's where it gets me, why would there be multiple? Is there somewhere else I need to be looking? Thank you for letting me pick your brain. |
![]() Join Date: Dec 2013
Re: SBC Engine numbers
The smaller numbers are the vin of the car or later model truck it came from , The V0429TDB are the engine codes . Is the dip stick on the drivers or passengers side?
![]() a quick looks shows TDB to be a 72-80 307 The V shows as a Flint built engine https://www.nastyz28.com/gm-chevy-co...s-suffix-7.php
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-04-2022 at 10:46 AM. |
Drivers side dipstick
![]() Join Date: Dec 2009
V= Flint
04=April 15 = 15th day of the Month Link:https://nastyz28.com/gm-chevy-codes/...s-suffix-7.php TDB = 1972 307 or 1980 ?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I'd be doing some more checking the 0010 is a good block and from what I've seen usually signifies a 350 ? is it a 2 barrel or 4 barrel carb ? I'd have to pull the oil pan and check if it's a 2 or 4 bolt main before I'd trade it away , Maybe the guy wanting to trade for it sees something we can't ? post a picture of the whole engine .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() ![]() Join Date: Jan 2005
There should be a casting date code on the passenger side top back of the block behind the intake manifold. The last digit will be the year.
I've been all over that engine gawd knows what I have disconnected (wires need cleaned up anyway)
I'm about ready to pull it so I can see 👀 but I'll check on passengers side once I warm up a bit. |
There's a LOT going on there , late model power brake booster , should pull vacuum from port on the manifold in front of the distributor not the carb , pcv isn't hooked up should go to the port currently used by the brake booster , Long water pump and altenator on passenger side along with type of valve covers looks like 1980 .
![]() What transmission is in it ? post a picture of the whole truck .
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 12-04-2022 at 01:59 PM. |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Yes! And there appears to be no check valve in the booster!
I'd also rotate the throttle linkage rod 180º on the firewall side lever so that the pull isn't so far off-axis. That's minor, though.
Yeah it was cobbled when I got the truck and after I installed the crossmember and brake booster I also cobbled it to test the brake function.
That's what I found when I went to adjust the clutch and that matched the quality white paint that was implement paint with a PAINTBRUSH. ![]() That's what happens when you grab a trailer friend and drive 4hrs to get a marketplace "Good deal" trying to replace my beloved 1966 k10, Last edited by Sun Baked; 12-04-2022 at 05:35 PM. Reason: Add the transmission pic |
Identifying the motor is one thing. It could already be a .60 over block too. Regardless of what the numbers say it was born as, I'd be more interested to see what any machining work or lack thereof says about it NOW.
I'd question anyone wanting to trade an LS for an unknown SBC straight up, just right off the bat. Either can be picked from a yard for the same amount, and i'd snag a newer roller block over old school any day of the week. That aside, after the LS and trans is aquired, another large chunk of money is mandatory to make sure it actually runs. Trans controller, ECU or EFI swap, motor mounts, radiator, accessories, gauges, trans mount, possible rear gearing, brakes to stop it, etc. You could scrape by and piece a lot of it together, or open your wallet and start counting by the thousand. |
![]() Join Date: Feb 2000
As stated above TDB suffix was used on 1972 307 and 1980 350 truck engines. Given the block casting is 3970010 that rules out the 307. 307 block castings were 3970020, 3970024, 3956632, 3932371, 3932373, 3941174, 3914636, 3914635. Appears you have a 1980 350 175hp truck engine (blue paint is a clue as well), you will still have to pull the pan to determine if it is a 2 bolt or 4 bolt main.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#13 |
Hope you have better luck than me. I have hit all the sites I can find including here and haven't figured out what I have yet.
My problem is my last three alpha characters don't match any data base I have found: V0430FSD CF/203864 (Could be "CE" which would be for a warranty replacement)
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
#14 | |
![]() ![]() Join Date: Apr 2022
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
| Bookmarks |
