Old 12-05-2022, 05:29 PM   #1
CK5
CK5's Avatar
Firewall question...
So question for you guys, this is the inner firewall right behind the radio area on a 72 Blazer, does this look correct or is there a piece missing etc.?
TIA
CK5.com
1972 Blazer Build
CK5 is offline   Reply With Quote
Old 12-05-2022, 10:09 PM   #2
Tmend
Tmend's Avatar
Re: Firewall question...
Some progress is better then no progress
Tmend is online now   Reply With Quote
Old 12-06-2022, 03:58 AM   #3
Richard
Looks like something is fastened by glue/caulk or other means to provide a support for radio or something else. Maybe see a bolt hole still there for the stock speaker/rear radio support in the pic. Some Blazers had no speaker hole in dash. Radio speaker was mounted under heater, A/C controls. Cannot say which design is more common. Would bet under dash is more common.
Richard
Old 12-06-2022, 01:04 PM   #4
CK5
CK5's Avatar
Yeah, weird looks like an inner panel is missing?
CK5.com
1972 Blazer Build
Old 12-06-2022, 02:23 PM   #5
Tmend
Tmend's Avatar
This is true sir about the speaker. However the bracket would still get mounted to firewall regardless of speaker configuration as it holds the rear bracket for the radio. Original posters photo looks like cowl has rust issues and maybe why the area looks tampered with
Old 12-06-2022, 02:52 PM   #6
CK5
CK5's Avatar
I do believe the rear radio support bracket does get mounted to the missing firewall piece for both speaker locations, I would think it would be the same for trucks as well?
No cowl rust issues that I can tell, just a little surface patina that would be on the inside of any enclosed part of a Blazer. If I run across another 67-72 that's being parted out I will take a closer look and see if I can remove that piece.
CK5.com
1972 Blazer Build
Old 12-06-2022, 08:08 PM   #7
CK5
CK5's Avatar
Hmm, A previous owner did a TBI swap and put the computer on top of the radio, I wonder if they flattened that section to make room? Always fun trying to figure out what a PO did.
CK5.com
1972 Blazer Build
