Old 12-06-2022, 10:05 AM   #1
Oregon 1967 GMC
Oregon 1967 GMC's Avatar
Another Overheating Mystery
After 5-10 minutes 400 sbc is heating up to 220° I turn off and notice the radiator feels cool. Have replaced thermostat, (180°) got air out by filling and running even jacking up front end. Temp sensing unit from classic instruments does not have adapter that can trap air. Laser thermometer shows temps are reading correctly. I plan on replacing water pump next. I just finished rewiring entire truck and installed 4 row radiator because I installed air conditioning
Thought I had air pockets but I've done everything to get the air out. Any suggestions?
Hey man
67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603
Oregon 1967 GMC is offline   Reply With Quote
Old 12-06-2022, 10:07 AM   #2
Oregon 1967 GMC
Re: Another Overheating Mystery
It was running fine before so it's not the head steam holes or anything like that. Can someone flip photo? I tried.
Hey man
Old 12-06-2022, 10:13 AM   #3
truckster
truckster's Avatar
Here you go.
Just because you changed the thermostat doesn't mean it's good. Have you tried running without one to see what happens?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
1972 K/5 Blazer CST 4WD
1963 Corvair Monza Spyder Turbo convertible
1995 Camaro Z/28
truckster is offline   Reply With Quote
Old 12-06-2022, 10:13 AM   #4
kwmech
What was/has changed from before?
Old 12-06-2022, 10:28 AM   #5
Oregon 1967 GMC
Originally Posted by truckster View Post
Here you go.
No but I will. Was just hoping it would fix itself 😄
Hey man
Old 12-06-2022, 10:29 AM   #6
Oregon 1967 GMC
Hey man
Old 12-06-2022, 10:35 AM   #7
SRU1436
Are you reaching these temps while idling or driving? Is the AC on or off when you reach these temps? What kind of fan you you have? Fan shroud? How big are the cores on the radiator? I had the same problem on my chevelle after AC install. The AC condenser blocks a lot of air flow, it should be (I believe and if I remember right) based in vintage air directions about 1.5 inches away from radiator. My fix was add a HD fan clutch to my mechanical fan.
SRU1436 is online now   Reply With Quote
Old 12-06-2022, 10:54 AM   #8
Oregon 1967 GMC
Idling and driving
AC on and off
Clutch fan with shroud half in half out as direction say.
I'm thinking some air possibly left in system and tired water pump.
Hey man
Old 12-06-2022, 11:20 AM   #9
Grumpy old man
Grumpy old man's Avatar
when you turn on the heat is it working and temp dropping ? I'm pretty sure the vintage air A/C system has a heater coolant cut off and you may have trapped air in the system are both heater hoses getting hot ? Maybe stuck closed and trapping air in the system ? do you have an overflow tank ? just a guess .
https://www.summitracing.com/parts/sum-361-180
Use a Summit thermostat with the bypass in it or just drill a couple 1/8 " holes in a standard thermostat to help relive trapped air .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-06-2022, 11:33 AM   #10
72SB
The fan is not on backwards...is it?
how many blades?
IMHO fewer (2 row) but larger row (1 1/4" to 1 1/2") is better than smaller 4 row radiators
72SB is offline   Reply With Quote
Old 12-06-2022, 12:21 PM   #11
SRU1436
Idling and driving
AC on and off
I’d look at the fan clutch, if it’s a Hayden it will have a number on there. You can’t look up the number on their website and it will tell you what speed the fan turns when fully engaged. As an example on mine, it was a standard fan clutch and spun at 50-60% shaft speed when engaged. That wasn’t pulling enough air, I replaced with a HD fan clutch which spun at 80-90% shaft speed when engaged, which pulled enough air to cool the engine down.
I’m not an expert by any means, my recommendation is to do one modification/change at a time to see if it helps, and start with the easy and cheaper stuff first.
Good luck.
Old 12-06-2022, 12:50 PM   #12
Oregon 1967 GMC
Good luck.
Good advice
Hey man
Old 12-06-2022, 12:51 PM   #13
Oregon 1967 GMC
how many blades?
5 blades and I wish it was on backwards
Hey man
Old 12-06-2022, 01:10 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
5 blades
My K20 has a factory 7-blade fan (18") on a HD Hayden 2747 clutch and it does not overheat. If purging air from the system doesn't do the trick, maybe consider upgrading to a 7-blade on a HD clutch (if yours is standard duty).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 12-06-2022, 01:35 PM   #15
72SB
My 5 blade would not keep up when I put in my built 357...7 blade fixed that
Also if you don't have a HD fan clutch, you need one
Old 12-06-2022, 02:05 PM   #16
Oregon 1967 GMC
Thank you
Hey man
Old 12-06-2022, 02:26 PM   #17
samert111
samert111's Avatar
Does it run cooler and stay steady temp with the heat control on hot but without the fan running?
If so it needs the heater circuit open as a bypass loop to keep constant flow of coolant past the sending unit
I just went thru this on my 68 with the vintage air and 350 CI. Temp would climb up to 240 then bounce back down to 200 then back up again repeatedly. Once I turned the temp control to hot it would drop to 185 and stay there all day.
I tried everything including drilling holes in the stat, burping the system repeatedly but no luck.
I ended up adding a bypass loop from the unused coolant port in the intake to the unused port on top of the water pump and problem solved.
I can't explain why it works but it does.
samert111 is offline   Reply With Quote
Old 12-06-2022, 03:52 PM   #18
RichardJ
I was thinking the same as grumpoldman and samart111. Vintage Air sells this heater hose bypass. It's intended mainly for fnord application. Check the heater hose temperatures as grumpy suggested.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 12-06-2022, 09:41 PM   #19
KQQL IT
At the body shop.
KQQL IT's Avatar
I put a high flow water pump on my 400 and it held the T Stat closed.
Took it out ran cool, ended up back with a stock water pump and the same Stat. Never an issue since.
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 12-07-2022, 05:59 PM   #20
MikeB
MikeB's Avatar
FYI, Vintage Air says to mount it as close to the radiator as possible without touching, so condenser and rad don't rub each other.
The closer the better, otherwise the fan(s) will draw air from the gaps between rad and condenser because it's the path of least resistance.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-08-2022, 10:31 AM   #21
rockyrivermark
Maybe try pulling stat completed and see what happens.
Get IR temp gun and get temps at stat housing.
Both top and lower radiator hoses hot?
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 12-08-2022, 01:35 PM   #22
Oregon 1967 GMC
I'm going to be doing that this coming weekend and post an update
Hey man
Old 12-09-2022, 09:02 PM   #23
SRU1436
You may be right, I don’t recall. For some reason 1.5 inches popped in my head.
Old 12-09-2022, 09:11 PM   #24
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Can't help with your problem but to check a thermostat put it in a pot of water and see if it opens when the water starts heating up. Bought a new thermostat to goin my newly rebuilt 400 engine and checked it with pot of water before it was installed.
1992 K1500 GMC Suburban
" In the end, we only regret the chances we didnt take "
" Time is the only currency we spend without knowing the balance, use it wisely ." ..
Old 12-09-2022, 10:36 PM   #25
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Remember when you could buy a new thermostat (or almost any part) and it worked, right out of the box? I still remember my fury when I put a rebuilt water pump on a car in the early '80s, and it leaked. I was working as a piece-work mechanic, and was set to bill the parts store for the labor to replace the defective pump, but the owner talked me down off the wall. Make your stuff right. I busted my hump to make sure that a vehicle I worked on was done right, especially the brakes, the first time. It's embarrassing to have someone come back and your diagnosis or repair is wrong...especially the brakes. Did I say that twice? Why, yes I did, and you all know why.
~Steven
Simi Valley, CA
