Old 12-08-2022, 03:39 PM   #1
PbFut
Gas Tank Vacuum
I've owned the truck (72 GMC C20) less than a year. I've had it apart and not drivable more than running (by choice). Recently back on the road, I notice the gas tank has a pretty strong vacuum on it when I open the cap. I don't recall this happening previously but the old cap was not sealing. There is a new cap from Brothers on the filler neck and says on the sticker it is a sealed cap, watch for splash or something to that effect.
Is the cap defective or this normal? Shouldn't the cap allow air in, but not out? It's pronounced enough that the tank sounds like it is deforming as I'll hear the gas slosh and sounds like the tank wall pops out from the deflection from vacuum. Or at the station after diving a a half hour or so, I open the cap and air rushes in and you can here the tank go back to shape. That seems excessive.
Wouldn't it also effect fuel delivery?
PbFut is offline   Reply With Quote
Old 12-08-2022, 04:22 PM   #2
howzzzit
howzzzit's Avatar
Re: Gas Tank Vacuum
You don't have the emissions set up on a C20 do you? My 72 C10 has rhe emissions set up and it uses a non vented cap. Bet you should be using a vented cap. Someone on here will know for sure.
howzzzit is offline   Reply With Quote
Old 12-08-2022, 04:33 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Gas Tank Vacuum
The Evaporation Control System was only used on 1/2T trucks (and cars, ofc) in '72. 3/4T trucks need a vented cap.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-08-2022, 05:02 PM   #4
dagnabbitt
dagnabbitt's Avatar
Re: Gas Tank Vacuum
I have the same deal with my 72 GMC 2500, I usually twist the cap open after a long drive to let some air in. Doesn't seem to affect performance in any way and I never thought anything of it but I suppose I might have the wrong cap too.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-08-2022, 06:46 PM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Gas Tank Vacuum
Having to pull suction isn't going to be doing the fuel pump diaphragm any favors. You can get vapor lock easier, too.
~Steven
Simi Valley, CA
