Old 12-09-2022, 12:24 AM   #1
Mr_Rich
Mr_Rich's Avatar
Trans selector switch
My '89 K1500 got side-swapped parked on the street a couple of years ago and I've had it on non-op since then. The left tail light was broken. The damage was not severe visually but a lot of parts were damaged that weren't obvious. I replaced the taillight lenses and circuit boards with the newer design. My darn backup lamps aren't working. They flash a bit when the selector lever is moved to the R pos. That led me to the trans selector switch at the base of the steering column. It's marked 22509632 which may have been superseded with a part no. 22514861. It looks like it might snap on in place somehow since I didn't see any mounting screws. Has anyone replaced that part? I don't want to break it trying to remove the darn thing.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 12-09-2022, 12:28 AM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Trans selector switch
Pretty sure the switch is adjustable. Sounds like it's a little off.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 12-09-2022, 12:33 AM   #3
Mr_Rich
Mr_Rich's Avatar
It doesn't look like it. No mounting screws I saw. I could be wrong but it's in the twenties outside and I won't look at it again until later tomorrow.
1989 K1500 Chev. EC
Old 12-09-2022, 12:53 AM   #4
pjmoreland
pjmoreland's Avatar
I've got an '89 as well, and I had to replace that switch after I broke the actuating tab off while disassembling the steering column a couple of months ago. Anyway, it just snaps into the column without any screws. It is adjustable by pushing the outer portion of the body left or right. It will make little ratcheting/clicking sounds as you adjust it.
pjmoreland is online now   Reply With Quote
Old 12-09-2022, 07:35 PM   #5
Mr_Rich
Mr_Rich's Avatar
Thanks for that fact. I probably would've damaged it without that knowledge. As it was I tried adjusting it in two click increments and I still didn't get lights. Perhaps the switch is bad. The tail/ brake lights are good.
1989 K1500 Chev. EC
Old 12-09-2022, 09:53 PM   #6
Just call me Sean
There's a specific way to adjust it, with a certain size drill bit inserted into a hole. I usually put it in neutral and move it until the lights come on.
Old 04-16-2023, 01:04 PM   #7
Mr_Rich
Mr_Rich's Avatar
I've had to set this problem aside for a while. The weather is getting better and it's time for my truck. Is there a trick to removing this switch from the base of the steering column? I don't want to break it.
1989 K1500 Chev. EC
Old 04-16-2023, 06:34 PM   #8
pjmoreland
pjmoreland's Avatar
There are two large fingers on the side of the switch that's facing the firewall. These two fingers are snapped into two small rectangular holes in the column housing. Use a small screwdriver to pry the fingers out of the holes. There are also two very small tabs on the side of the switch away from the firewall that hook onto the edge of the large slot on the column housing. You can rotate these tabs out after the fingers are released.
Old 04-16-2023, 06:35 PM   #9
pjmoreland
pjmoreland's Avatar
More pictures
Old 04-19-2023, 12:19 PM   #10
Mr_Rich
Mr_Rich's Avatar
Thanks for the detailed reply! Where did you find the new part at?
1989 K1500 Chev. EC
Old 04-19-2023, 12:30 PM   #11
pjmoreland
pjmoreland's Avatar
I bought it at a local parts store. O'Reilly sells them.
https://www.oreillyauto.com/detail/c...1?q=NS41&pos=1
