Old 12-09-2022, 04:23 PM   #1
cj847
cj847's Avatar
Saginaw power steering pumps
I am having an issue with saginaw pumps. I have replaced dozens over the years without an issue.
The issue: Pump is on an LS swap. It is a 2001 hydroboost pump. It was not producing enough pressure to make the power steering feel right. It is better than non power, but not nearly as easy as power steering. So, I bought a rebuilt unit and it felt about the same. Then I pulled it off and "hotrodded" it like the offroad guys do (2 #4 flat washers under the relief valve spring). Literally no change.
PS> It has a new steering box and new hoses.
I guess I am looking for ideas. I am considering:
-buy a pump for an 86 c10
-buy a high dollar aftermarket pump like borgeson or others.
What do the experts say?
cj847 is offline   Reply With Quote
Old 12-10-2022, 03:01 AM   #2
Bob B.
Re: Saginaw power steering pumps
Pulley size? Maybe you are turning it too slow.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 12-19-2022, 03:43 PM   #3
BigCountryx
BigCountryx's Avatar
My steering is almost too light with the stock 2001 5.3 pump. I changed to a quick ratio Borgeson gear box and it's a little firmer, but still softer than most modern power steering setups. Not sure what you have going on unless there might be a restriction somewhere.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped
1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant
BigCountryx is offline   Reply With Quote
Old 12-19-2022, 06:47 PM   #4
cj847
cj847's Avatar
That is my concern. I have a jeep with 5.3 and a saginaw box and it is fine.
On this truck I have a lares quick ratio box, all new hoses and remanufactured pump. The only thing I changed was to put the outlet from my old pump into the reman pump. (ie so I could use flare hose end vs O ring). I did check and it had the same ID and length of the outlet that the pump came with. I suppose I could have got a bad hose?
Can anyone confirm there is no pressure bypass in the steering box? I know that rack and pinions can bypass but I've never heard of a 700 or 800 saginaw box bypassing.
The "right" thing to do is test the pressure with a gauge. But the auto parts stores don't rent that tool and it costs more than a new pump.
Old 12-20-2022, 10:44 PM   #5
R.O.B.
I think it's your quick ratio box, not the pump. I remember on my 86 Trans Am that had the WS6 package, that steering was very sporty. Firm, better than manual by far, but not Cadillac slush by any means
R.O.B. is offline   Reply With Quote
