Old 12-10-2022, 12:49 PM   #1
72malibu
Active Member
72malibu's Avatar
Rear Parking Brake Cable Bracket -- Left/Driver?
Does anyone know where I can one? I don't see them repro'd. This is for a 1975 2wd c15 (Gentleman Jim).
I bought two NOS brackets, with different GM part no. stickers on them (6272301 and 6272302) but they are identical! Both are for the right/passenger side.
Here are photos of what I have -- I need the driver side :-)
The way the brackets mount, they go under the frame, with the 2 rivet holes to the outside, and with the cable hole to the inside and forward of the rivets.
If I try to use these on the driver side, the rear PB cable would be too far back or outside the frame.
72malibu is offline   Reply With Quote
Old 12-11-2022, 11:30 AM   #2
72malibu
Active Member
72malibu's Avatar
Re: Rear Parking Brake Cable Bracket -- Left/Driver?
Hmm, not sure, but it looks like I may need PN 6272303 or revised PN 341273.
I'm not finding anything with those numbers, hoping somebody has an old frame or an idea where I can find a bracket.
Old 12-12-2022, 08:28 AM   #3
chrismoore701
chrismoore701's Avatar
old school junk yard, they are still out there
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 12-12-2022, 05:03 PM   #4
Dead Parrot
I looked at the ones on my C10. They are mirrors of each other. Looks like one could be made out of some angle iron. Do a little cutting, drill 3 holes, install. Didn't look real close but they might be riveted. A yard find might have to be ground off.
Dead Parrot is offline   Reply With Quote
Old 12-12-2022, 07:10 PM   #5
72malibu
Active Member
72malibu's Avatar
Yes to both -- mirror image and riveted.
They're stamped with a gusset in them, so they'd be stronger than a 90-degree bend.
Old 12-13-2022, 10:26 PM   #6
Factory Guy
Factory Guy's Avatar
I would go find a junkyard that specializes in Squares, even if you have to drive some (I have to drive 2 hours{each way} to get to mine).
Factory Guy is offline   Reply With Quote
Old 12-13-2022, 10:30 PM   #7
72malibu
Active Member
72malibu's Avatar
Thanks, will have to see if there's one in the Maryland/Virginia vicinity -- haven't heard of one but they probably exist.
