Old 12-12-2022, 06:16 PM   #1
Peanut74
Precision door seal question
I bought a complete rubber set from a online vendor. All the rubber is from Precision including the door seals. What I can't figure out is do I have the glue or press on? If glue on what type glue do you use?
The seal acts like press on but falls off after a bit. Below is a picture of the seals profile.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 12-12-2022, 06:45 PM   #2
sick472
sick472's Avatar
Re: Precision door seal question
My press-on Precision seal had to be hand butted on, meaning it took some force. It has been on for about 2 years and has not slipped in the slightest. I'd say you have the glue-on type. The glue to use is the 3M weatherstrip adhesive. Use the black as the yellow will stick out like a sore thumb if you get it goo-ed out somewhere. There is a proper way to apply the adhesive and a wrong way.
This is a good video to help you along...
https://www.youtube.com/watch?v=qDBojIza-TA
It is not as easy as they make it look, but it's not bad either. Just take your time and have some mineral spirits and a few small rags handy for when it gets all over you and where it's not supposed to.
The portion of the seal the slips over the pinch welds will be stiff and has hidden wire in it that keeps it pinched in place. It will be rather stiff and takes some effort to bend it. The glue-on type will be much more flexible, like a noodle.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 12-12-2022, 08:28 PM   #3
Peanut74
Thanks 472. That is what I thought that they were glue on. I'm like Pigprn when I paint so should be interesting. I will have to go get some 3M so I can start the fun.
I take it the formed corner goes on the A-pillar to roof, correct?
Old 12-12-2022, 11:20 PM   #4
Sheepdip
Sheepdip's Avatar
You can follow up with some "Goof-Off" or like cleaner before the 3M adhesive completely sets. You will need plenty of throw away rags.
Sheepdip is offline   Reply With Quote
Old 12-13-2022, 06:09 PM   #5
Peanut74
Well I went ahead and glued my Precision door seals on. I went with the "less is better" when I glued them on. I even managed to come away not looking like Pigpen which is a first. Tomorrow I will double check and make sure I have a good seal.
