Old 12-19-2022, 08:51 AM   #1
A1971Blazer
A1971Blazer's Avatar
BFG T/A or Cooper Cobra?
I should get my wheels back from powder coat this week and I'm trying to decide on a tire combination..and brand. for my '67 C10
Going with about a 3/5 front/rear drop and thinking of running a 295/50R15 rear and a 235/60R15 front tire....
Debating between Cooper and BFG....?
Thoughts and/or experiences....thanks!
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 12-19-2022, 09:12 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: BFG T/A or Cooper Cobra?
Cooper tends to last a bit longer for me.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-19-2022, 09:23 AM   #3
Joyridin
Did you look at Mickey Thompson tires? I believe Cooper owns the and they seem to be a bit nicer.
Joyridin is online now   Reply With Quote
Old 12-19-2022, 09:58 AM   #4
Grumpy old man
Grumpy old man's Avatar
Why the short tires ? What size wheels are you using ? Are you going with white letters out or black wall?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-19-2022, 10:27 AM   #5
A1971Blazer
Dang Grumpy that's a lot of questions for a Monday morning....
.....I want the width of the 295....and they are 26½" tall
.....Wheels are 15 x 8½....keeping 6 lug
.....and I'm up in the air with the white letters...I thought about 1 side in...other side out....? seriously, undecided...
1967 C10 Step side
1968 C10 Step side
Old 12-19-2022, 10:34 AM   #6
72SB
The BFG's TA RWL (raised white letter) tires of late (last few years) have had issues with the white letters yellowing. They clean up with cleanser and a brush...but will start to yellow again. Have them on my 67 Camaro
I have BFG BSW on the C10
72SB is offline   Reply With Quote
Old 12-19-2022, 10:41 AM   #7
I prefer the Coopers over BFG
Old 12-19-2022, 11:16 AM   #8
Grumpy old man
I spent some amount of time before buying what I ended up with this tire /wheel combo, This is what I found . I couldn't find any 29" tires in 60's width , after dropping the truck 3.5/5 down I wanted side wall to help with suspension and fill the wheel wells , My upper rear well measures right at 28" empty . I did not want to have to play games with the speedometer reading right . I did not want to increase rpm's just to run wider tires, Running a 4 speed Muncie also was a consideration , I wanted old school 15" wheels 6 lug and I'm a chrome guy and who doesn't love old school rallye wheels? I didn't want to be constantly polishing aluminum wheels . Even tho I like slots I sold 2 sets on the board to avoid that , I'm running BF Goodrich T/A's 255x70x15's all the way around white letters out because I think it's old school cool , I bought a spare to take along on longer trips and I wanted it to fit any corner , So no staggered tires , I've had the Cooper Cobras before and they're good tires but I think they are a harder compound . I was looking for driveabilty over "the look" . I plan on DRIVING the truck for many years . I've spent years building this truck the way I wanted it and Not trying to follow the herd , But that leads to major project creep .
After it was all said and done I have about $2,000.00 in them for 5 mounted balanced with center caps . Tires are expensive and I wanted to be able to rotate them .
This tire calculator link gives you an idea of the differences .
https://tiresize.com/comparison/
Old 12-19-2022, 11:33 AM   #9
CAMAROBOY68SS
CAMAROBOY68SS's Avatar
yep can confirm, BFG white letters yellow almost right after you take the blue off. Another problem Ive had is that they are much hard to get white again like older sets. I have a set of rollers that way old but I was able to get the bright again. The pair that are a year old, they are yellowed for good.
The Twins:
1968 C10 SWB - Blue 327/5 Speed
1968 Camaro SS/RS - Blue 327/4speed
C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278
The "Others"
1933 Ford Pickup (Camaro in disguise)
2017 Camaro SS
Life long Chevy guy
CAMAROBOY68SS is offline   Reply With Quote
Old 12-19-2022, 11:58 AM   #10
Grumpy old man
Westley's Bleche White . Now called Black magic bleche wite used with a soft bristle brush will keep your white letters and white walls brite white . I'm sure they changed the name because everyone's running black walled tires today .
https://www.walmart.com/ip/Black-Mag...E&gclsrc=aw.ds
Old 12-19-2022, 12:11 PM   #11
A1971Blazer
Yes sir....I've seen your truck up close and personal a couple of times...the look is outstanding...
I will have the 5.7 LS1/4L60e combo with 3.73 gear...the 4L60 has a 3.06 low gear and with the 3.73 and my heavy foot....I think it gonna want to have a tendancy to have some...let's say...."tire slippage"...
That's why I was leaning toward the 295/50...it's almost 12" wide
I will have aluminum rims but they are getting powder coated to avoid the polishing dilemma...
BTW...here's the cab I got from you.....the one of the roof is the most accurate of the true color
1967 C10 Step side
1968 C10 Step side
Old 12-19-2022, 12:13 PM   #12
kwmech
Years ago when i was selling tires I'd say go with the Coopers, but now I think their quality has gone down in the past 20 years. I ran them on everything I owned and never had any issues with them
Old 12-19-2022, 12:15 PM   #13
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I would go BFG's where I am at now. I have been a Cooper buyer for a while, the last couple of sets average about three years here before the sidewalls start cracking really bad. I have two Cooper tires now that are leaking out of the sidewall (now flat) and the tread looks great. If you can keep them in a garage and out of the UV contact most of the time then the Coopers may work. I have over a bakers dozen worth of trucks and just cannot keep them all inside. Unless it has changed, the 275-60-15 Coopers were made in Mexico(according to Tire Rack SPECS). I would have thought the sidewalls would have been tougher, just hasn't been the case for me. I have done both, cleaned and used tire protection then just washed and still get about the same results.
Up there in TN you may be ok with the Coopers. I spent a lot of time in the Volunteer State during my journeys with the 101st....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-19-2022, 12:20 PM   #14
71meangreenc10
This is what I have experienced in the last couple of sets.....The down hill part...
Smitty
71 C30 Wrecker
Old 12-19-2022, 12:26 PM   #15
Grumpy old man
Attachment 2241193
Attachment 2241194
Attachment 2241195
Attachment 2241196
It looks GOOD , But I'm thinking it would look a whole lot better still sitting under a pile of parts in the corner of my garage where it sat for years .
Old 12-19-2022, 12:46 PM   #16
A1971Blazer
that made me .....worst part was digging it out huh?
just look at it this way....it gave you room to pile more stuff...
Did you sell off any more of your excess yet?
1967 C10 Step side
1968 C10 Step side
Old 12-19-2022, 12:53 PM   #17
Grumpy old man
Here are a couple pictures of when I found it and when I started stipping the paint off , I'm glad she's going back on the road . With the rear window decals , CHEVROLET RACING AND KILL ALL TIRES !
Old 12-19-2022, 02:00 PM   #18
Grumpy old man
Yeah great , more room to pile stuff up , it's already full of seats and parts I need for a "special 67" I have stashed away for years in an old barn , The 67 long bed and short bed parts trucks I have here are going to the farm , They are too good to scrap out given the parts value they still have and titled matching cabs and frames are getting harder to find .
Old 12-19-2022, 02:02 PM   #19
A1971Blazer
If you need some help....give me a shout my friend....
1967 C10 Step side
1968 C10 Step side
Old 12-19-2022, 03:20 PM   #20
truckster
truckster's Avatar
I've never been disappointed with BF Goodrich. I've tried all kinds of tires, including very expensive Pirellis, but I come back to BFG. The Pirellis would stick to a wall if you wanted to drive up one, but they didn't last worth squat. My Michelins last forever, but I don't like the ride as well. The last set of Coopers I had was several years ago, so I can't say anything about current quality.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-19-2022, 07:29 PM   #21
CG
BlahBlahBlah
If you are a white letters out guy I would go with BFG. To me the lettering on them is better than the Coopers. Maybe get a white lettering stick if they tend to yellow these days. As far as which is better if I was going black walls Id get the ones with the best warranty and make sure you keep all the paper work and dont lose it like I always manage to do.
Old 12-19-2022, 08:32 PM   #22
pjmoreland
pjmoreland's Avatar
Here are the prices at the local tire store here:
295/50R15:
BFG = $225 ea
Cooper = $210 ea
235/60R15:
BFG = $181 ea
Cooper = $162 ea
4 BFGs = $812
4 Coopers = $744
The BFGs cost 9% more than the Coopers. While that isn't a big difference, it was enough to get me to go with the Coopers. The Coopers have a 40,000mi warranty. I don't see a warranty listed on the BFGs.
I had several sets of Radial T/As a bunch of years ago, and I burned through the rear tires quite quickly, but I can't blame the tires for that. I like how both brands of tire look in terms of the profile of the tread at the shoulder of the tire, and I think they look quite similar to each other.
pjmoreland is offline   Reply With Quote
Old 12-19-2022, 09:24 PM   #23
HO455
Post Whore
HO455's Avatar
I've run 275-60-15's for the last 15 or more years on my daily drivers. Cooper last about 8 to 10k miles longer but have poor wet weather traction. The BF Goodrich's have better traction wet and dry but with lower mileage.
I was impressed with the Les Schwab store brand as they wore like the Coopers and had the traction of the BFG's. Unfortunately the customer service at Les Schwabs became so terrible after Les died I gave up on them.
So living in Portland Oregon I opt for the wet traction advantage of the BFG's.
RIP Bob Parks.
Old 12-22-2022, 05:11 PM   #24
70cst
70cst's Avatar
This
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
