Old 12-19-2022, 12:44 PM   #1
K10-Kansas
K10-Kansas's Avatar
Rag joint, steering coupler won't go on
Same spline count, measures to be the same size, but won't go on in place of the old rag joint. I'm putting the new one on exactly how the old one came off and it won't go on lined up in the exact same flat spot position. Not even with a hammer. I haven't tried hitting it too hard. The only thing I can think of is that the old rag joint and the steering box shaft have been worn and damaged in the exact same pattern together so now something new won't fit on because it doesn't match that deformed pattern.
Help. I don't want to replace my steering box too. Any advice?
K10-Kansas is offline   Reply With Quote
Old 12-19-2022, 01:51 PM   #2
cj847
cj847's Avatar
Re: Rag joint, steering coupler won't go on
There are two couplers available for 67-72 trucks. One is 3/4" (36 spline) the other is 13/16" (31 spline). It appears you have the 13/16" version.
I had the same problem about 6 months ago.....
cj847 is offline   Reply With Quote
Old 12-19-2022, 03:34 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Rockauto part number 200 or 201. Look for Lares product. I always keep one of each on hand.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 12-19-2022, 05:34 PM   #4
K10-Kansas
K10-Kansas's Avatar
Yeah, the old and new in the picture are the 31 spline. Any advice on getting it on?
Old 12-19-2022, 05:55 PM   #5
geezer#99
geezer#99's Avatar
You could try chamfering the edge.
Small round file or emery cloth.
Or spread the clamp a bit with a flat screwdriver.
Old 12-19-2022, 06:01 PM   #6
geezer#99
geezer#99's Avatar
Thinking more on it, best to spread the clamp end.
Old 12-19-2022, 06:05 PM   #7
kwmech
Don't know if it is my monitor or not, but to me the new rag joint looks like it has more splines compared to the old
Old 12-19-2022, 11:42 PM   #8
K10-Kansas
K10-Kansas's Avatar
Yeah I could imagine it's real hard to tell from the picture I counted them real carefully a few times and they're the same number.
Old 12-19-2022, 11:45 PM   #9
K10-Kansas
K10-Kansas's Avatar
I think this is a great idea. It looks like a hydraulic spreader is 120 bucks. I'm not sure how else to spread them apart.
Old 12-19-2022, 11:58 PM   #10
LockDoc
The Older Generation
LockDoc's Avatar
You should be able to gently drive a chisel or something like that in just far enough to get it on the shaft. Don't go any farther than you absolutely have to or you won't be able to get the bolt back in.
LockDoc
Leon
Old 12-20-2022, 01:51 AM   #11
RustyPile
RustyPile's Avatar
Do you have a pair of channel-loc pliers?? Thread the bolt into the coupler, leaving ~ 1/8 - 3/16" space under the head.. One jaw of the pliers in the slot, and the other jaw on the head of the bolt. Squeeze the pliers taking note of the gap width. Work slowly, checking the fit occasionally until the coupler slides over the shaft.
RustyPile is offline   Reply With Quote
Old 12-20-2022, 09:24 AM   #12
Grumpy old man
Grumpy old man's Avatar
Place 2 flat blade screw drivers in the gap and spead the screw drivers apart thus widening the gap enough to slide it in place , it doesn't take much to get it on then install locking bolt . easy peasy .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-22-2022, 12:13 AM   #13
K10-Kansas
K10-Kansas's Avatar
After trying a few different ways, I finally found a method that worked.
Old 12-22-2022, 03:48 PM   #14
72SB
BFH & pry bar....aka speed wrench.
good you FIO OP
72SB is offline   Reply With Quote
