Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-19-2022, 11:07 PM   #1
yuccales
yuccales's Avatar
2014 Tahoe fog lamp removal
Instead of removing the inner fender, pressing the tabs down with needle nose pliers, etc, try this. Get a 3/8 box wrench and slip it over the stud. This squeezes the tabs closed. Then use your thumb and push that stud through the hole. I pressed the three studs a little at a time so as to not bind up the lamp assembly. After removing the wire, about 1 minute to remove. No needle nose therefore no blood blisters.
yuccales is offline   Reply With Quote
