Old 12-22-2022, 02:38 AM   #1
Tmend
Tmend's Avatar
Fuel gauge
I read the (fuel gauge diagnostics 101) before I go pulling my gauge out I have a question. I read and understand that with the wire removed from the fuse box the gauge will read 3 o’clock. When I fill up gauge registers 1/4 tank past full and 1/4 tank when empty. I removed the wire from fuse box and gauge went to little past 4 o’clock (see photo) . Is it safe to say gauge is bad ?. Has new sending unit but you never know. Thanks much
Some progress is better then no progress
Tmend is offline   Reply With Quote
Old 12-22-2022, 05:35 AM   #2
Re: Fuel gauge
Most of the time when I see that, the ground strap for the sending unit is not good. Might have to clean the contact areas or redo the ground strap at the tank.
Old 12-22-2022, 10:32 AM   #3
Tmend
Tmend's Avatar
Re: Fuel gauge
Since I don’t know what ground strap you’re referring to you may be right lol. I’ve only checked the single brown wire connection at the sending unit and made sure the tank was also secure. Can you share what strap you’re talking about . Thanks much
Old 12-22-2022, 11:06 AM   #4
Grumpy old man
Grumpy old man's Avatar
Re: Fuel gauge
Your gauge is working , before you start replacing parts . Use the old school repair method , Replace the brass float with the jeep plastic float , they don't leak or disolve in todays gas , then bend the float rod slightly to adjust the gauge to read correctly . no need to pull the gauge cluster , Just the sending unit
You have to remember it's 1960's technology .
https://www.classicindustries.com/pr...ew-32134373246
https://www.summitracing.com/parts/o...iABEgKc7PD_BwE
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-22-2022, 11:50 AM   #5
pjmoreland
pjmoreland's Avatar
Re: Fuel gauge
In your photo, it is pointing past 3:00. The gauges I've tested are normally horizontal with the wire disconnected. In all three cases you listed (sender wire grounded, sender wire disconnected, tank full), the gauge is reading abnormally high. It sounds to me like the needle is rotated too far clockwise on the shaft. I have never removed one of these needles before, but if that is possible without damaging anything, I'd be inclined to remove and reinstall it at EMPTY with the sender wire grounded, assuming you have verified you have good grounds first. EMPTY is the most important reading, in my opinion.
pjmoreland is offline   Reply With Quote
Old 12-22-2022, 02:17 PM   #6
Tmend
Tmend's Avatar
Re: Fuel gauge
Agreed I think needle is off. Later today I’m disconnecting cluster without removing and plugging in another one I have I’ll update with findings
Old 12-22-2022, 04:11 PM   #7
Tmend
Tmend's Avatar
Re: Fuel gauge
Bad fuel gauge. Here is another restored cluster with an oem gauge and reads correct . The one in truck now is a aftermarket gauge
Old 12-22-2022, 09:28 PM   #8
Yamariv
Yamariv's Avatar
Re: Fuel gauge
Attachment 2242430
Nice, thanks for the update!
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
