Old 12-25-2022, 09:12 AM   #1
K10-Kansas
K10-Kansas's Avatar
Dash bent weird. How? And how to fix?
A previous owner somehow bent the dash. How in the world could this have happened? Also, I pushed up on this with a few hundred pounds of pressure to lift the left side to match the right side and it barely moved. Any ideas on straightening this up?
K10-Kansas is offline   Reply With Quote
Old 12-25-2022, 09:26 AM   #2
Getter-Done
Getter-Done's Avatar
Re: Dash bent weird. How? And how to fix?
PO probably pry it down to fit the late model steering column.
Do you have a welder?
I would make a 4-legged stand.(incorporate seat bolt holes in the fixture for no movement)
So that you could use a bottle jack underneath it.
To slowly move it back in shape.
Thats my first idea if the floorpan is solid enough.
Hope this helps.
The early bird gets the worm,
85 Chevy K-20
Old 12-25-2022, 09:46 AM   #3
Grumpy old man
Grumpy old man's Avatar
That's accident damage , someones right knee did that , use the gauge cluster bezel to check alignment .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 12-25-2022, 10:03 AM   #4
Grumpy old man
The right side of the dash ( right of the column ) is the weaker side of the lower dash , There's no reason for someone to intentionally bend that section .
Old 12-25-2022, 10:24 AM   #5
Getter-Done
Good point
The gauge cluster will tell the story.
So It is posible that it needs to be pulled down.
85 Chevy K-20
Old 12-25-2022, 10:32 AM   #6
I wonder was the hoop ever cut and rewelded? I'd cut it loose, get the dash straight, and re-weld the hoop. Use your dash bezel for reference. Probably was an accident. Look the truck over for front end hit clues.
Old 12-25-2022, 11:41 AM   #7
Warrens69GMC
Warrens69GMC's Avatar
The hoop is what's wrong IMO. I will bet if you center it again while pulling down on the right side it will go back into position. throw a level against the lower dash and see where it is high/low.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-27-2022, 03:27 AM   #8
Richard
Does not look like 1.5" in pic, maybe .5-.75 ? Holding bezel up is a good idea. Would check the plane that bezel attaches to on lower edge. If lower center section is pushed back toward firewall it would pull up.
Richard
Old 12-30-2022, 03:35 PM   #9
68 C10 Driver
That is really odd. Not sure if that is accident damage, I would think that if it were, the right side would have been pushed inward toward the firewall, not downwards.
Here are a couple pics of mine when I was refurbishing the dash.
68 C10 Driver is offline   Reply With Quote
Old 12-31-2022, 07:27 AM   #10
K10-Kansas
K10-Kansas's Avatar
Hope this helps.
After removing a brace bolt, it bent back up fairly easily.
1971 C10 body. 76 4x4 chassis cut to short frame. Crate 350 2nd Gen small block. 4BBL Holley 4160. 4L60 transmission. ~ James
Old 12-31-2022, 07:29 AM   #11
K10-Kansas
K10-Kansas's Avatar
Great idea. I went ahead and lined up the broken guage cluster and will further tweak it with the new guage cluster when I set it in there.
Old 12-31-2022, 07:31 AM   #12
K10-Kansas
K10-Kansas's Avatar
Yeah, that worked. After unbolting the hoop it bent back in place. I think there is a chance the previous owner bent the dash and busted the guage cluster bezel trying to fit a late 70s steering column in there.
Old 12-31-2022, 08:54 AM   #13
I bet you are right about that. Glad you got it straightened out
Old 12-31-2022, 06:02 PM   #14
54blackhornet
54blackhornet's Avatar
You guys ever watch Columbo ? Great detective work !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-31-2022, 09:58 PM   #15
K10-Kansas
K10-Kansas's Avatar
Getting ready to put the new steering column in I see that the previous owner cut a portion of the support away that holds the left side of the half-moon clamp for the steering column. How important is that half-moon clamp?
Old 01-01-2023, 08:26 AM   #16
I think you're going to want to fix that. All the weight of the column hangs off that clamp and it helps stabilize that area across the bottom of the dash where you just straightened it. It's the other half of the upper 'U' that bridges that gap to brace that area
Old 01-01-2023, 10:01 AM   #17
K10-Kansas
K10-Kansas's Avatar
Thanks. The right side nut for the half moon clamp can be connected but the left side is gone. I guess my choices are to:
strap it down to anything,
weld in something to strap it to,
go looking for a replacement part to replace the part that's cut.
Old 01-01-2023, 10:03 AM   #18
K10-Kansas
K10-Kansas's Avatar
Another picture of the cut support
Old 01-01-2023, 10:04 AM   #19
K10-Kansas
K10-Kansas's Avatar
Another picture.
Old 01-01-2023, 10:31 AM   #20
Rods
Rods's Avatar
Just my two cents but It seems to me the best approach to fix your situation is to just replace the entire pedal assembly
It would be the best way to correct someone else’s mistake instead of trying to repair it.
The pedal assembly is a important safety feature in the bracing up of the dash and firewall and by replacing the pedal assembly you will be able to correct the dash alignment and what other mods were done by PO in that area.
That’s a tough area to weld at especially with all the wires and its a small working area.
I think replace pedal assembly and you will be happier and finish with less work and worry and a better repair in the end.
Az
Rods is offline   Reply With Quote
Old 01-01-2023, 11:32 AM   #21
K10-Kansas
K10-Kansas's Avatar
Yeah, I'd rather do it right. I found a used assembly online.
Old 01-09-2023, 10:53 AM   #22
old51sedan
old51sedan's Avatar
I had a problem with mine being bent a little, I found that an old fashion bumper jack work well for what I needed to do.
old51sedan is offline   Reply With Quote
Old 01-10-2023, 08:24 AM   #23
K10-Kansas
K10-Kansas's Avatar
When you pushed up on one side did the other side try to come up also?
Old 01-10-2023, 12:23 PM   #24
old51sedan
old51sedan's Avatar
No, but what worked for me may not work for you depending on the situation, all I can say is if you have an old bumper jack it may be worth a try.
