Old 01-05-2004, 03:55 PM   #1
TIMSPEED
TIMSPEED's Avatar
Hmm..funny idle problem, seems like a miss, but not really..
Lately, my truck has been idling really funny. It won't hold an idle worth a crap! It seems like it's missing, but it's not a consistent thing. It's like the truck loses power for a split second, but only randomly, without pattern. (Like if you disconnected a spark plug, it'd always miss in that same spot.) So, it's hard to say if it's my carb causing me problems, or my plugs are already fouled. (They're almost a year old bosch platinum's with maybe 3k miles on them; although I've been running pretty rich, so that may have slightly fouled them)
Also, when it cuts out, it affects everything. Like, if I have the headlights on, the tach light will dim when it cuts out. It's very split-second though, like a "blip". It's only while it's in drive too...when I put it up into park (park idle is about 950-1000) it's not even there, but when I drop it into drive (drive idle is about 750) it's there.
Any ideas?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 01-05-2004, 04:33 PM   #2
r0lf-
Hotwheels?
r0lf-'s Avatar
Hrmmm... sounds interesting. I would say that the missing your hearing is just your uneven pipes with no X-over like me, but its affecting your whole truck. Got me stumped.
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 01-05-2004, 06:03 PM   #3
allthrtl
Available for Adoption
allthrtl's Avatar
Hard to say, a vacuum leak will cause an irratic idle, but shouldn't affect the electrical.....Sounds like a loose connection somewhere...battery, starter, alternator....hard to say without actually seeing it.....good luck....
Michael
1983 C10 SWB 2001 Silverado SWB 1995 Corvette
allthrtl is offline   Reply With Quote
Old 01-06-2004, 12:42 AM   #4
TIMSPEED
TIMSPEED's Avatar
Well, I unplugged a relay under the dash the other day, because I thought that was my horn relay...I'll try plugging it back in and see if it makes the idle any different...
See Them Here
