Old 12-26-2022, 07:45 PM   #1
chev-obsession
chev-obsession's Avatar
Hydro boost lines
I’m finally going to install my hydro boost unit… and after a long search in the forum I didn’t see a lot of info about this in the 60-66 department.
Are there any pre-made lines that I can use from a certain vehicle that work well in the 60-66 trucks? Can I make my own hard lines and take them to a hydraulic shop to have the rubber hose crimped on? I’m trying to stay away from AN fitting stuff.
What is the best option?
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 12-26-2022, 08:59 PM   #2
Getter-Done
Getter-Done's Avatar
Re: Hydro boost lines
Here is some of the stuff I have saved.
Link: https://67-72chevytrucks.com/vboard/...droboost+lines
The early bird gets the worm,
85 Chevy K-20
Old 12-27-2022, 12:18 AM   #3
SkinnyG
SkinnyG's Avatar
I had mine made at Princess Auto, out of hydraulic line. They crimp the appropriate ends on. I'm sure you have a tractor place near by that can do the same.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 12-27-2022, 12:05 PM   #4
88Stanger
88Stanger's Avatar
So I have a unigue situation in that I have a Type 2 GM power steering pump (High Pressure or standard GM Pressure) that must go to my Hyrdo boost then onto a Heidts Pressure reducing valve and then onto my Rack - so 3 high pressure lines and then 4 low pressure return lines. NOTE: if you run a rack, you need to reduce the standard GM pressure for the Rack BUT you want the higher pressure for the hydro boost, reason for the "cheap" pressure reducing valve. I have a complete hyrdaulic line kit that came with hydro boost, but I need more lines than it comes with, so... I am going to use PTFE lines and 6an ends for this back to a remote reservoir, and then a 10an line from the reservoir back to the pump. The PTFE lines are capable of withstanding the high pressure side if needed for custom routing or the no need for hydraulic press. Just another thought....
John 3:16 - Saved me... God Bless
88Stanger is offline   Reply With Quote
Old 12-27-2022, 12:06 PM   #5
88Stanger
88Stanger's Avatar
WAIT What the heck!! You are in my town?! Heck, let me know if you need some hometown help!
Old 12-29-2022, 02:06 AM   #6
chev-obsession
Thanks for the info I will post my results. Might be a while
Old 01-01-2023, 12:34 PM   #7
gmcdeadhead
gmcdeadhead's Avatar
i used the booster off a 1987 r30 chevy truck , put it in my 1966 c20 , with the 350 engine i added, i kept the stock 1987 lines, they worked
gmcdeadhead is offline   Reply With Quote
