Old 12-28-2022, 09:04 PM   #1
3x2GTO
Stepside gas filler neck info needed
I've started the search for a gas filler tube for my 77 stepside and have no idea as to wat they look like. Can someone post up a picture of one, and are the side specific? Thanks!
3x2GTO is offline   Reply With Quote
Old 12-29-2022, 09:28 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Stepside gas filler neck info needed
Is the cap on the driver side or passenger?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 12-29-2022, 01:38 PM   #3
77 ChevySport
Here are a few pictures that may help. Before restoring the fuel tank which is on the Passenger side. Some pictures of the original fuel inlet hose and a reproduction hose WHICH DID NOT FIT. No one makes a hose that will fit the 77 Chevy Shortbed Stepside. Your original better be is good shape to use. Hope this helps. Larry
Name:  77 Chevy Sport Pick Up 003.JPG
Name:  77 Chevy Sport Pick Up 007.JPG
Name:  77 Chevy Sport Pick Up 008.JPG
77 ChevySport is offline   Reply With Quote
Old 12-31-2022, 07:09 PM   #4
pound41
Not sure about a 77 but my Dads 76 has a neck and a small hose. At the time I replaced the tank no hose was available, LMC was the 1st I saw with a repo which I bought I sure others now have them. 76 the tank is on the passenger side. I can get a picture when I am at my parents house
pound41 is offline   Reply With Quote
Old 01-01-2023, 09:00 AM   #5
77 ChevySport
If you put a search on the board you will find a "in depth" discussion on
this subject. I'll go from memory now>
The position for the inlet for fuel for stepsides changed from year to year; thus the length/turns on the inlet hose are not the same and will not work for ALL stepsides.
IIRC the 77 and 78 where the same so the hoses are unique for those years. No one AFAIK(Could have changed) makes one. The one I bought shown in the picture comes out 2" short and will not work but may work for other years.
BTW: If you think you could just get a "universal" radiator hose and use it is a bad idea. Radiator hoses where designed to carry water/anti-freeze and
not fuel. If used for fuel it COULD brake the rubber off in small pieces and go to the fuel tank then the carburetor which is not good. Larry
Old 01-03-2023, 08:31 AM   #6
chrismoore701
chrismoore701's Avatar
I found a hose that closely represented what I needed and had to cut and twist it to get it to fit, not sure what I used, a pipe and hose clamps
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
