where is the headlight relay on a 1977 gmc 3500
i bought a set of h4 headlights to replace the old ones on my 77 k3500 now they flicker on and off i can barley hear a clicking noise behind the left side of the instrument cluster but i dont see no relay
#2 | |
Re: where is the headlight relay on a 1977 gmc 3500
The factory wiring diagrams are located here, if it helps trace down the problem. http://67-72chevytrucks.com/vboard/s...d.php?t=545416
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
thanks for the reply i have always had a 70s model trucks but never had to look for a headlight relay on them what throwed me off was the real faint sound of a relay clicking on and off when the headlights came on and off still dont know where its coming from i am gona buy a heavy duty headlight wiring harness from lmc when i bought the new headlights i didnt think i would have to change anything but to run them i got to change the wiring harness thanks
Thermal overload in the headlight switch probably.
Do your lights a favor and wire up an external relay harness for your headlights, might as well get the most out of those H4's. |
![]() Join Date: Dec 2009
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 85 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
| Bookmarks |
