Old 12-31-2022, 01:02 PM   #1
Warrens69GMC
Warrens69GMC's Avatar
1967 3OTT transmissions?
What transmissions came behind the inline sixes with the 3OTT in 1967 C10's?
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 12-31-2022, 01:31 PM   #2
jocko
jocko's Avatar
Re: 1967 3OTT transmissions?
67 CS10 3OTTs:
Standard: Chevrolet synchromesh (2.94, 1.68, 1.00 and 3.14 reverse - only 2nd and 3rd were synchronized).
Optional: Chevrolet fully synchronized (2.85 1st and 2.95 reverse) - this trans was standard for CE10.
Optional: Chevrolet fully synchronized trans mentioned above - with overdrive.
Hope that helps
Old 12-31-2022, 01:57 PM   #3
Warrens69GMC
Well I was trying to see if it was a Saginaw or a M20, etc.....
Was looking to see what the torque rating on these transmissions are.
I'm looking at a 1967, longbed Six cylinder/ 3ott, and getting up to speed on this year-only items.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-01-2023, 11:00 PM   #4
68 C10 Driver
It is a Saginaw, mine was similarlyequipped. I replaced that transmission with a M20, which is a 4 speed. The truck was converted to a floor shift back when my father-in-law owned it, so to me the M20 made sense...and it is period correct for the truck.
Here is a pic of my M20, I have since changed out the rods for the correct ones for the truck and eliminated the plate aluminumshifter mount and mounted the shifter on the tailcone like it should be:
68 C10 Driver is offline   Reply With Quote
Old 01-02-2023, 12:55 AM   #5
jocko
jocko's Avatar
Sorry Warren, I was trying to answer the question asked in the first post.
For a 68 I6 3OTT truck, there were only three possibilities - all posted above.
Have you seen the SPID yet?
  • If no "M##" RPO is listed, it came with the standard Syncromesh 3OTT.
  • If RPO M17 is listed, it came with the optional Fully Synchronized 3OTT (which was also standard on a CE10). This RPO could only appear on a CS10.
  • If RPO M10 is listed, it came with the optional 3OTT w/overdrive.
I "think" all the 3-speeds available in that year were Saginaw, but don't quote me on that... Don't know the torque ratings. Do the torque ratings matter? It's a 3OTT... none of them were made for racing but they're all stout enough for a 68 CS10. The real difference between the 3 3OTT possibilities isn't necessarily their torque ratings - rather it's just different variations of synchronization & 1st and Reverse gear ratios - and whether there is an overdrive gear.
A 3OTT truck would not have an M20 RPO listed as that is a truck 4-speed option - generally the SM465 in 1968. Not to be confused with a car 4-speed of the same era, different animal.
Old 01-02-2023, 01:24 AM   #6
Warrens69GMC
I haven't even seen the truck yet. The seller says it's a 292 with a 3OTT. I was doing homework to see how it was equipped.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-02-2023, 02:07 PM   #7
Keith Seymore
Keith Seymore's Avatar
Excellent response and totally correct.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-03-2023, 09:14 AM   #8
It gets confusing with GM using M20 for completely different transmissions.
Old 01-03-2023, 10:25 AM   #9
Keith Seymore
Couple things:
a) Yes - RPO codes do get reused during different eras of production
b) Also - the RPO code is not intended to indicate a specific brand or supplier. Even if the code is consistent (ie, "manual trans - non overdrive", or "Rear Axle - 3.42 ratio") it doesn't mean it's tied to a manufacturer like Dana, or New Process, or Saginaw or American Axle or whatever. Only the enthusiasts try to do that.
K
1979-1986
1986 - 2019
Old 01-16-2023, 04:11 PM   #10
Warrens69GMC
HERE'S the gem. I suppose I could have done worse.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-16-2023, 04:13 PM   #11
Warrens69GMC
More
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-16-2023, 04:14 PM   #12
Warrens69GMC
Engine 250
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
