Old 01-07-2023, 03:06 AM   #1
Tezjoe84
Tezjoe84's Avatar
Shocks! Need some info please
Hey guys, just picked up a truck to tinker with and swapped the wheels out to 18/20’s. The front is a good bit higher than I would like so ordering a 3in drop spindle and would like to know what shocks would work best for street driving, just a cruiser, no racing and such.
I don’t really want to spend $600-$800 on a set of QA1’s but would like a decent shock that’s good with the lowered front end. Let me know what you guys use and what I may need to do please!
Tezjoe84 is offline   Reply With Quote
Old 01-07-2023, 09:52 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Shocks! Need some info please
I run KYB shocks on some of my street driven builds. There are lots of part numbers available with different compression and rebound dimensions to fit lots of ride heights.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-07-2023, 10:06 AM   #3
MT65
What vin63 said….you need to be at your desired ride height to get some measurements….its not a perfect science
MT65 is offline   Reply With Quote
Old 01-07-2023, 02:06 PM   #4
SkinnyG
SkinnyG's Avatar
Dropped spindles require no change in shocks length.
KYB are decent, I would buy those.
I run Monroe Blue on my '77 C10 daily driver, they are a bit on the soft side, but perfectly fine.
I bought Monroe Black (better than the blue) for my '61. Untested at the moment, but I've run blacks on other vehicles and been pleased.
Don't stress it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-07-2023, 02:50 PM   #5
theastronaut
theastronaut's Avatar
I've used KYB Gas-A-Just on the front of a couple of lowered trucks and they ride well and dampen body motion pretty well. They're just slightly on the soft side for my preference but definitely better than a stock or lower level gas shock. If you're only doing spindles you can use stock fitment shocks.
theastronaut is offline   Reply With Quote
Old 01-08-2023, 09:56 AM   #6
Chevy nutcase
Chevy nutcase's Avatar
As someone said earlier, you dont need to change shocks with a spindle drop. Something I didn't know when I lowered mine lol so I have four brand new CPP drop shocks if yours was spring dropped and you need a pair
Chevy nutcase is offline   Reply With Quote
Old 01-09-2023, 12:14 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
KYB makes three levels of shocks with more aggressive dampening as you go up.
