Old 01-08-2023, 10:06 PM   #1
Accelo
Accelo's Avatar
Blasting away (hood springs)
Thought I would share my fixture I manufactured for blasting and powder coating hood springs. Works like a champ and no one get hurt. I use the small ratchet block to stretch the springs onto the fixture. Then blast them and powder coat them without removing them from the fixture. When done I use the same ratchet block to remove them. Perfect job every time. And the process leaves no lines. Pictured is a spring blasted before installation on the fixture. The uncleaned debris is obvious.
Cheers.
Accelo is offline   Reply With Quote
Old 01-08-2023, 10:34 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Blasting away (hood springs)
I’ve heard not to powder coat any metal that has been hardened . It may be a myth but heating metal to 400 degrees can alter its hardness and temper. I temper Steel at 400 to temper for knives .
I like the fixture
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-08-2023, 10:34 PM   #3
zicc1835
zicc1835's Avatar
great idea
zicc1835 is offline   Reply With Quote
Old 01-09-2023, 03:12 AM   #4
Accelo
Accelo's Avatar
Might be playing on the knife's edge. VBG.
I have practical knowledge, it works and the hood stays up.
Cheers.
