Old 01-08-2023, 10:38 PM   #1
Furno68C20
3 speed behind a 292
Is a 292 too much for the 3OTT?
The 292 was usually with a sm420 or sm465 right?
I have a 1/2 ton with a bad 250. I can either put in a 307 or a 292.
Any suggestions? The 6 swap would be much easier.
Furno68C20 is offline   Reply With Quote
Old 01-09-2023, 03:19 AM   #2
Accelo
Accelo's Avatar
Re: 3 speed behind a 292
No the 3-speed was available with the larger motors including the 350ci.
Listed as HD, maybe others will know how to ID the non-heave duty 3-speeds?
It appears the HD 3-speed was even an option behind the 400 V8.
List below is from 1971 C10;
Accelo is offline   Reply With Quote
Old 01-09-2023, 07:08 AM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
I might be a little biased, but I say go with a 292. Love mine that I swapped from a 250.
Just be aware the 292 takes a different passenger side motor stand that can be hard to find sometimes.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 01-09-2023, 08:46 AM   #4
I've had two big block trucks with 3spd transmission. The 3spd was standard transmission in the 4wds, even K/20s.
Old 01-09-2023, 10:35 AM   #5
old51sedan
old51sedan's Avatar
My truck came with a 250 and an automatic. I switched to the 292, you will need a different frame mount on the right side only. The theromstat housing is a little different than the 250 too. Also if you have PS on the 250, it will not fit the 292, other than that your good to go. Picture shows difference in housing.
old51sedan is offline   Reply With Quote
Old 01-09-2023, 05:12 PM   #6
Furno68C20
I’ve got the passenger side mount. Everything else should line up where the 250 sat.
One other question, can I use the 250 radiator for the 292?
Old 01-10-2023, 12:26 PM   #7
old51sedan
old51sedan's Avatar
I did with mine.
Old 01-10-2023, 02:02 PM   #8
Steeveedee
Who Changed This?
Steeveedee's Avatar
Originally Posted by old51sedan View Post
I did with mine.
And you put AC in it, right? Did you install a fan shroud? I don't recall all the details. Just that I really like that truck!
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-10-2023, 08:02 PM   #9
54blackhornet
54blackhornet's Avatar
Years ago I was given a 68 GMC 1500 with a blown 250. I located a 292 just because I figured why put a 250 back in when the 292 would fit ? I never could keep the crappy Chinese rubber engine mounts from ripping out. The three on the tree and stock 250 rear end imo did not play well together.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 01-12-2023, 11:01 AM   #10
old51sedan
old51sedan's Avatar
As you can see it has a full fan shroud, I bought this truck out of southern CA about 6 years ago and it came with a 3 core radiator and the shroud. Yes I added the vintage air, a 200-4R and the PS.
Old 01-12-2023, 11:59 AM   #11
Keith Seymore
Keith Seymore's Avatar
You should be ok.
We had a 292 bored to 305 cu in, with three Rochester 2bbls (and Pontiac tripower progressive linkage) with a Saginaw four speed behind it, and it was fine.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-12-2023, 03:21 PM   #12
RichardJ
I am thinking it might have made a difference if it was a C10 or a C20. My 2500 GMC that i have had since '85, has the 292 that originally had the 3spd. the truck has a steel bed, leaf springs and a Dana 60 with 4.56 gears. The rear half of the 2-piece drive shaft is beefy and looks at home with the DANA. The front half of the drive shaft was smaller, anemic looking and seemed to belong with the small non-syncro 3spd. It looked like the truck was built to be a heavy duty 3/4 ton and I don't think GM wanted a 3spd in there, but they went with what some people ordered.
I replaced the 3spd with a SM465 and put 3.54 gears in the DANA. The new, longer front half of the drive shaft is more appropriately sized.
The truck is much happier with the truck 4spd.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 01-12-2023, 03:41 PM   #13
RichardJ
A 292 bored .060 is 301 cubes, which is what I have. You have to go .090" to get 305.23 cubes. I've seen one that was .080" over that ran for years, but eventually it cracked a cylinder bore.
Old 01-12-2023, 10:40 PM   #14
Furno68C20
Good info here. The 292 I have was out of a grain truck. 28k miles on the truck Score! Are the rubber mounts different on the grain than the c10/20/30?
I’d prefer to use the OEM mounts instead of new.
Old 01-12-2023, 11:31 PM   #15
LockDoc
The Older Generation
LockDoc's Avatar
I have two complete 292ci engines out of the larger grain trucks but I have never looked at the mounts that close. I know one of them has power steering on it. I will have to check them out. I think the block pads would be the same but the frame brackets may be different than the 292ci pickups.
I will try to remember to check them out.
LockDoc
Leon
Old 01-24-2023, 08:49 PM   #16
Furno68C20
The OEM c50 and up rubber engine mounts will fit a c10/20/30 frame.
LockDoc
Old 01-24-2023, 09:36 PM   #17
LockDoc
LockDoc's Avatar
I wrote myself a note to do this tomorrow. Thanks....
LockDoc
Leon
Old 01-25-2023, 01:27 PM   #18
LockDoc
LockDoc's Avatar
The rubber pad mounts are different for the C40, 50, 60 292 but the block brackets are the same, so the C10, 20, & 30 rubber pad mounts will work with the C40, 50, & 60 block brackets.
The big truck rubber pad mounts are about 3 x 5 inches and mount horizontally. 3 Bolt holes on the top side and 1 center bolt on the bottom. I will remove one of them and update this with a picture when I come back in later....
EDIT: Here are the pictures.
1st picture is front of big truck rubber mount. Second is the back. Third shows how holes line up with a C10, 20, 30 rubber mount, and 4th is the block bracket. The bottom hole in the block bracket has a weld nut in it.
LockDoc
Leon
Old 01-25-2023, 04:43 PM   #19
LockDoc
LockDoc's Avatar
Bump to top.... Edited my last post and added pictures.
LockDoc
Leon
Old 01-25-2023, 09:36 PM   #20
Furno68C20
Nicely documented Dr.
Old 01-26-2023, 12:23 AM   #21
LockDoc
LockDoc's Avatar
Thanks.
LockDoc
Leon
