Old 01-09-2023, 01:38 AM   #1
howzzzit
howzzzit's Avatar
Answer to 72 C10 cab mounts
Maybe someone has the answer concerning the cab mounting. Why did GM use 2 different diameter bolts and route one from the top to bottom and the other from bottom to top?
howzzzit is offline   Reply With Quote
Old 01-09-2023, 08:29 AM   #2
Sheepdip
Sheepdip's Avatar
Re: Answer to 72 C10 cab mounts
Yes... the smaller diameter bolts are for the rear mounts and they face up from the bottom into a captured nut underneath your fuel tank, otherwise you'd have to pull the tank to change them out.
The larger diameter bolts are for the front, and they drop in from the floor board facing down.
Here's a reference video provided by Holley. The kit shown DOES NOT include radiator support bushings, they should be replaced at the same time.
https://www.holley.com/products/exte...6372962676&hsa
Sheepdip is offline   Reply With Quote
Old 01-09-2023, 11:51 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Many times you will find that the head of the front bolts are tack welded to the floor recess. Probably to enable one person to install the nuts from the bottom on the assembly line.
LockDoc
Leon
Old 01-09-2023, 02:09 PM   #4
howzzzit
howzzzit's Avatar
Thanks. I know how they should be installed, but I am wondering why GM used 2 different size bolts and why is the front installed from the top and the rear installed from the bottom. Seems like the could have used cage nuts for the front as well as the rear. Must have been for their convenience? Just lay awake at night wondering. Ha.
Old 01-09-2023, 03:01 PM   #5
damnyankee36
damnyankee36's Avatar
Any time I see a situation like this I figure it's purely an assembly line convenience as LockDoc mentioned.
And, as Sheepdip mentioned the rear are installed that way because of the fuel tank.
damnyankee36 is offline   Reply With Quote
Old 01-09-2023, 05:55 PM   #6
RustyPile
RustyPile's Avatar
LockDoc
Mine were welded like that.. Normally, a floor jack can be positioned under the rocker panel to lift each side only an inch or two. Nothing has to be disconnected (fuel lines, ground straps, steering column, etc). Just loosen the bolts on the side not being lifted and remove the bolts on the lifted side.
Leaving the welded bolts in place, the body has to be lifted several inches... Lots of extra work.. Using a small Dremel and cut-off wheel, I cut the welds loose and removed the bolts.
RustyPile is offline   Reply With Quote
Old 01-10-2023, 11:06 AM   #7
72c20customcamper
72c20customcamper's Avatar
The fronts can be replaced and tightened by one person with a little yoga involved I’ve done two trucks . The rear is because the tank was most likely installed before it was mated to the frame so they used cage nuts . They did it in a manner to facilitate ease on the line . No real regard for fixing them later .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 01-10-2023, 11:17 AM   #8
On the front you want a bolt head up so there is a flat bolt head pulled down tight and not a bolt shank sticking up. The rear is because there is no bolt-through access without removing the tank. My guess is the tank is already installed in the cab before the cab is bolted to the chassis. Which is the opposite of how us home-built guys normally would do it.
Old 01-18-2023, 02:41 AM   #9
howzzzit
howzzzit's Avatar
Pulled back my carpet this evening. Guess I'm a really lucky guy. No tack weld on the front bolt head. Living right.
